[应用相关] FMC+DAM驱动LVGL刷屏
647|0
 楼主| paotangsan 发表于 2025-4-13 07:19 | 显示全部楼层 |阅读模式
fm, FMC, DA, LVGL, AC, REA
前提条件
使用FMC驱动LCD刷屏
LVGL移植
开启DMA
需要开启MEMTOMEMDMA。
开启MPU
有MPU时需要
使能I-cache D-cache时
使用DMA传输数据时要保证数据的完整行和准确性
修改代码
逻辑
等待DMA传输完成然后再刷屏。
修改
在DMA初始化函数中最后添加
注册DMA传输完成调用函数。
HAL_DMA_RegisterCallback(&hdma_memtomem_dma2_stream0, HAL_DMA_XFER_CPLT_CB_ID, LVGL_LCD_FSMC_DMA_pCallback);
修改disp_flush函数
/*Flush the content of the internal buffer the specific area on the display
*You can use DMA or any hardware acceleration to do this operation in the background but
*'lv_disp_flush_ready()' has to be called when finished.*/
static void disp_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
    /*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
//     LCD_ShowPicture(area->x1, area->y1, area->x2 - area->x1+1, area->y2- area->y1+1, (uint16_t *)color_p);
        LCD_Address_Set(area->x1,area->y1,area->x2,area->y2); //写地址
        HAL_DMA_Start_IT(&hdma_memtomem_dma2_stream0, (uint32_t)color_p, Bank1_LCD_DATA, ((area->x2+1) - area->x1) * ((area->y2+1) - area->y1)); //写数据
    /*IMPORTANT!!!
//     *Inform the graphics library that you are ready with the flushing*/
//    lv_disp_flush_ready(disp_drv);
添加刷屏函数
刷屏函数
void LVGL_LCD_FSMC_DMA_pCallback(DMA_HandleTypeDef *_hdma)
        lv_disp_flush_ready(&disp_drv);
原文链接:https://blog.csdn.net/qq_41555003/article/details/134221469
