这个被Secured的GD32C103CB怎么解锁啊
1578|0
 楼主| LEARNSTM 发表于 2025-4-21 21:28 | 显示全部楼层 |阅读模式
Connecting ... - Connecting via USB to probe/ programmer device 0
- Probe/ Programmer firmware: J-Link V9 compiled May  7 2021 16:26:12
- Device "GD32E103CB" selected.
- Target interface speed: 4000 kHz (Fixed)
- VTarget = 3.293V
- Found SW-DP with ID 0x2BA01477
- DPIDR: 0x2BA01477
- CoreSight SoC-400 or earlier
- Scanning AP map to find all available APs
- AP[1]: Stopped AP scan as end of AP map has been reached
- AP[0]: AHB-AP (IDR: 0x24770011)
- Iterating through AP map to find AHB-AP to use
- AP[0]: Core found
- AP[0]: AHB-AP ROM base: 0xE00FF000
- CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
- Found Cortex-M4 r0p1, Little endian.
- FPUnit: 6 code (BP) slots and 2 literal slots
- CoreSight components:
- ROMTbl[0] @ E00FF000
- [0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
- [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
- [0][2]: E0002000 CID B105E00D PID 002BB003 FPB
- [0][3]: E0000000 CID B105E00D PID 003BB001 ITM
- [0][4]: E0040000 CID B105900D PID 000BB9A1 TPIU
- [0][5]: E0041000 CID 00000000 PID 00000000 ???
- Executing init sequence ...
- ERROR: Failed to connect.
Could not perform custom init sequence.
