-  /* Configure and enable the UART peripheral */
-     Cy_SCB_UART_Init(scb_0_HW, &scb_0_config, &CYBSP_UART_context);
-     Cy_SCB_UART_Enable(scb_0_HW);
-     /* 配置 UART 中断 */
-      Cy_SysInt_Init(&UART_IRQ_cfg, UART_InterruptHandler);
-      NVIC_EnableIRQ(UART_IRQ_cfg.intrSrc);  // 使能 NVIC 中断
-      // 当 RX FIFO 非空时启用 UART RX 中断
-      Cy_SCB_SetRxInterruptMask(scb_0_HW , CY_SCB_RX_INTR_NOT_EMPTY);
-      // 当 TX FIFO 未满时启用 UART TX 中断
-      Cy_SCB_SetTxInterruptMask (scb_0_HW ,CY_SCB_TX_INTR_LEVEL);
-     /* Enable global interrupts */
-     __enable_irq();
2、RX中断处理函数UART_InterruptHandler
- static void UART_InterruptHandler(void)
-     /* 检查是否 RX FIFO 非空 */
-     if (Cy_SCB_GetRxInterruptStatusMasked(scb_0_HW) & CY_SCB_UART_RX_NOT_EMPTY)
-         /* 读取接收到的数据 */
-         uint8_t rxData = Cy_SCB_UART_Get(scb_0_HW);
-         /* 存入缓冲区(可改为环形缓冲区) */
-         if (rxCount < RX_BUFFER_SIZE)
-             rxBuffer[rxCount++] = rxData;
-         /* 可选:检查结束符(如 '\n') */
-         if (rxData == '\n'&&rxCount>2)
-             // 可以设置标志位通知主循环
-                 atResponseReady=true;
-     /* 清除中断标志 */
-     Cy_SCB_ClearRxInterrupt(scb_0_HW, CY_SCB_UART_RX_NOT_EMPTY);
3、主循环处理
- if(atResponseReady)
-               uartRxProcessHandler();
-                rxCount=0;
-                atResponseReady=false;
- void uartRxProcessHandler(void)
- if(strstr(rxBuffer,"on")!= NULL){
-                 Cy_GPIO_Write(CYBSP_LED3_PORT ,CYBSP_LED3_PIN,1);
-                 enCapSense=true;
-         else if(strstr(rxBuffer,"off")!= NULL)
-                 Cy_GPIO_Write(CYBSP_LED3_PORT ,CYBSP_LED3_PIN,0);
-         memset(rxBuffer,0,sizeof(rxBuffer));
4、main函数中水位监测处理
- if(enCapSense)
-             uint32_t level_w_FR, level_wo_FR;
-         /* Scan the normal Liquid Level Widget */
-             Cy_CapSense_ScanWidget(CY_CAPSENSE_LIQUIDLEVEL0_WDGT_ID, &cy_capsense_context);
-         /* Wait until the scan is finished */
-         while(Cy_CapSense_IsBusy(&cy_capsense_context)) {}
-         /* Scan the Foam Rejection Widget */
-         Cy_CapSense_ScanWidget(CY_CAPSENSE_LIQUIDLEVEL0_FR_WDGT_ID, &cy_capsense_context);
-         /* Process all th widgets */
-         Cy_CapSense_ProcessAllWidgets(&cy_capsense_context);
-         /* Send capsense data to the Tuner */
-         //Cy_CapSense_RunTuner(&cy_capsense_context);
-         /* store the liquid level before and after foam rejection */
-         level_wo_FR = CY_CAPSENSE_LIQUIDLEVEL0_PTRPOSITION_VALUE->x;
-         level_w_FR = CY_CAPSENSE_LIQUIDLEVEL0_FR_PTRPOSITION_VALUE->x;
-         sprintf(cmd,"AT+MQTTPUBRAW=WATER004,%d,0,0",getDigits(level_wo_FR)+2);
-         Send_AT_Command(cmd, response, AT_TIMEOUT_MS);
-         sprintf(cmd,"%ld",level_wo_FR);
-         /* keep the compiler happy */
-         (void)level_wo_FR;
-         (void)level_w_FR;
-                 enCapSense=false;
5、发送AT指令
- bool Send_AT_Command(const char* atCommand, char* response, uint16_t timeout_ms) {
-     /* 清空缓冲区 */
-     memset(rxBuffer, 0, RX_BUFFER_SIZE);
-     rxCount = 0;
-     atResponseReady = false;
-     /* 发送 AT 指令(带换行符) */
-     Cy_SCB_UART_PutString(scb_0_HW, atCommand);
-     Cy_SCB_UART_PutString(scb_0_HW, "\r\n"); // 添加结束符
-     /* 等待响应 */
-     Cy_SysLib_Delay(timeout_ms);
-     /* 返回响应内容 */
-     strcpy(response, rxBuffer);
-     return true;
-  //WIFI模块RESET
-   Send_AT_Command("AT+RST", response, AT_TIMEOUT_MS);
-   //WIFI连接
-     if (Send_AT_Command("AT+CWSTATE?", response, AT_TIMEOUT_MS)) {
-                 if (strstr(rxBuffer, "+CWSTATE:2") == NULL)
-                     Send_AT_Command("AT+CWJAP=ssid,password", response, AT_TIMEOUT_MS);
-    //发送clientid,其中的clientid要替换成自己的
-     Send_AT_Command("AT+MQTTLONGCLIENTID=1892ce3cc45c4xxxxxxxxxxxxxxxx7", response, AT_TIMEOUT_MS);
-    //连接巴法云
-     Send_AT_Command("AT+MQTTCONN=bemfa.com,9501,0", response, AT_TIMEOUT_MS);
-   //发布WATER004主题登录指令
-     Send_AT_Command("AT+MQTTPUBRAW=WATER004/up,7,0,0", response, AT_TIMEOUT_MS);
-     Send_AT_Command("**n", response, AT_TIMEOUT_MS);
-   //订阅WATER004
-     Send_AT_Command("AT+MQTTSUB=WATER004,0", response, AT_TIMEOUT_MS);
-   //发布一条数据用于测试
-     Send_AT_Command("AT+MQTTPUBRAW=WATER004,4,0,0", response, AT_TIMEOUT_MS);
-     Send_AT_Command("25", response, AT_TIMEOUT_MS);
wifi模块初始化成功,并且mqtt连接成功,绿灯亮
通过巴法云APP,可以搜到WATER004,连接后可以设置为"液位监测"方便使用,可以看到测试数据25cm已经显示出来
点击进去,显示如下:
可以按这个按钮控制LED亮,使能液位监测标志,MCU会采集一次数据,并通过MQTT发送数据,这时手机APP显示的数据随之改变。
MCU发给WIFI模块日志:
WIFI模块发给MCU日志:
MQTT+CapSense的潜在使用场景:
1、远程鱼缸水位监测
2、远程降雨量测量
3、农田灌溉优化
4、洪灾灾害易发区监控
