[AVR单片机] LCD2USB
2940|3
 楼主| meteor01 发表于 2007-6-9 12:22 | 显示全部楼层 |阅读模式
Version 1.08(avrusb)/2.08(usbtiny): lcd2usb-2007-05-20.zip
All parts GPL compliant
Patch to make usbtiny version work when already plugged in at boot time
Both USB stacks updated to the latest versions
LCD Smartie driver
The ready-to-use LCD2USB.dll to be installed into the "displays" directory of LCD Smartie
And the source code archive LCD2USB-smartie.zip for the driver
Version 1.07/2.07: lcd2usb-2007-01-15.zip
Added usbtiny based version due to user request
AVR-USB version 1.07, USBtiny version 2.07
Version 1.06: lcd2usb-2007-01-14.zip
Improved contrast voltage generation (thanks to Tino Albecht)
Contrast and brightness settings are kept permanently in eeprom
Version 1.05: lcd2usb-2006-04-08.zip
Added Makefile to build testapp under MacOS X.
Version 1.05: lcd2usb-2006-03-18.zip
Updated to use the latest avrusb version.
Adjusted version numbering
Version 1.4: lcd2usb-2006-02-26.zip
Support for avrdude/USBasp added to Makefile
Version 1.3a: lcd2usb-2006-02-22.zip
Small improvements in windows support of test application.
Version 1.3: lcd2usb-2006-02-09.zip
Button support
Improved USB handling
Version 1.2: lcd2usb-2006-02-04.zip
Version 1.1: lcd2usb-2006-01-26.zip
Version 1.0: lcd2usb-2006-01-21.zip
相关链接:http://www.edn21.cn/bbs/viewthread.php?tid=5268&extra=page%3D1
maomao40 发表于 2007-6-9 12:28 | 显示全部楼层
好贴,顶!
zhangqibo 发表于 2007-6-9 14:29 | 显示全部楼层
转贴要注明出处
老外真强!
这里有更多:
http://www.obdev.at/products/avrusb/projects.html
aivenk 发表于 2007-6-9 21:32 | 显示全部楼层
能解释一下可以干什么用吗?
有一个那么大的屏幕为什么还要做个小的?
我还看过用老外FT245做过这玩意。
