[研电赛技术支持] CAN通讯实现1ms发送3帧+gd32f470
1053|0
 楼主| Zuocidian 发表于 2025-5-7 22:57 | 显示全部楼层 |阅读模式
本例子是在GD32f470芯片上实现的,通过配置CAN1初始化和发送函数,500k最大限度实现1ms发送3帧报文。
一、CAN1初始化
void Can1_Init(uint32_t baud,uint8_t MasterSlave)
        can_parameter_struct        can_parameter;
    can_filter_parameter_struct can_filter;
        /* initialize CAN register */
        rcu_periph_clock_enable(RCU_CAN1);
        can_struct_para_init(CAN_INIT_STRUCT, &can_parameter);
    can_struct_para_init(CAN_FILTER_STRUCT, &can_filter);//Initialization parameters
        can_deinit(CAN1);
        can_parameter.time_triggered        = DISABLE;
    can_parameter.auto_bus_off_recovery = ENABLE;
    can_parameter.auto_wake_up          = DISABLE;
    can_parameter.auto_retrans          = ENABLE;
    can_parameter.rec_fifo_overwrite    = DISABLE;
    can_parameter.trans_fifo_order      = ENABLE;
    can_parameter.working_mode          = CAN_NORMAL_MODE;
        if(baud == 125)
                //CAN baud AP1_60MHz/(20*(4+16+4))=125kHz
                can_parameter.resync_jump_width = CAN_BT_SJW_4TQ;
                can_parameter.time_segment_1 = CAN_BT_BS1_16TQ;
                can_parameter.time_segment_2 = CAN_BT_BS2_4TQ;
                can_parameter.prescaler = 20;
        else if(baud == 250)
                //CAN Baud AP1_60MHz/(15*(1+14+1))=250kHz
                can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;
                can_parameter.time_segment_1 = CAN_BT_BS1_14TQ;
                can_parameter.time_segment_2 = CAN_BT_BS2_1TQ;
                can_parameter.prescaler = 15;
        else if(baud == 500)
                //CAN baud AP1_60MHz/(15*(1+6+1))=250kHz
                can_parameter.time_segment_1 = CAN_BT_BS1_6TQ;
        else if(baud == 1000)
                //CAN baud AP1_60MHz/(15*(1+2+1))=1000kHz
                can_parameter.time_segment_1 = CAN_BT_BS1_2TQ;
    /* initialize CAN */
    can_init(CAN1, &can_parameter);
    /* initialize filter */
    /* CAN0 filter number */
    can_filter.filter_number = 15;
    can_filter.filter_mode = CAN_FILTERMODE_MASK;
    can_filter.filter_bits = CAN_FILTERBITS_32BIT;
        if(MasterSlave == 0) //Master
                can_filter.filter_list_high = 0x0000;
                can_filter.filter_list_low = 0x0000;
                can_filter.filter_mask_high = 0x0000;
                can_filter.filter_mask_low = 0x0000;
        else if(MasterSlave == 1) //Slave
    can_filter.filter_fifo_number = CAN_FIFO1;
    can_filter.filter_enable = ENABLE;
    can_filter_init(&can_filter);
        can_interrupt_enable(CAN1, CAN_INTEN_RFNEIE1);
         /* configure CAN1 NVIC */
    nvic_irq_enable(CAN1_RX1_IRQn, 6, 0);
二、CAN1发送函数
//CAN1修改
int SendByCan1(unsigned int std,void* data,const int len)
        can_trasnmit_message_struct TxMessage = {0};//Define Send Message Structure
        volatile uint32_t i = 0;
        uint8_t TransmitMailbox = 0;
        TxMessage.tx_sfid = std;
        TxMessage.tx_efid = std;
        TxMessage.tx_ft =CAN_FT_DATA;                    //Set the frame type of the message to be transmitted: data frame
    TxMessage.tx_ff =CAN_FF_EXTENDED;           //Extended identifier
        TxMessage.tx_dlen = (len> 8)?8:len;
    volatile uint8_t *psrc = (uint8_t*)data;
    for(i=0; i<len; i++)
        TxMessage.tx_data[i] = psrc[i];
        TransmitMailbox = can_message_transmit(CAN1,&TxMessage);//Start the transmission of a message
        i = 0;
        while((i<0XFFF))
        if(can_transmit_states(CAN1,TransmitMailbox) == 1)break;
        i++;
        if(i < 0XFFF)
                return 0;
        else
                return -1;
原文链接:https://blog.csdn.net/m0_37822396/article/details/147744684
