[STM32N6] 无法安装tensorflow2.8.3
1519|1
 楼主| 地瓜patch 发表于 2025-5-10 21:03 | 显示全部楼层 |阅读模式
执行pip install -r requirements.txt时,出现如下错误
ERROR: Could not find a version that satisfies the requirement tensorflow==2.8.3 (from versions: none)
ERROR: No matching distribution found for tensorflow==2.8.3
执行pip install tensorflow2.8.3时,同样出现如下错误
ERROR: Could not find a version that satisfies the requirement tensorflow2.8.3 (from versions: none)
ERROR: No matching distribution found for tensorflow2.8.3
 楼主| 地瓜patch 发表于 2025-5-11 22:46 | 显示全部楼层
结贴了,是python版本的问题,从3.9.4降到了3.8.0,可以正常安装tensorflow2.8.3
