[技术问答] 数据基本类型
1337|11
 楼主| gygp 发表于 2025-5-23 15:39 | 显示全部楼层 |阅读模式
一、C语言数据基本类型
在C语言中有6种基本数据类型:short、int、long、float、double、char
1)整型:short int、int、long int
2)浮点型:float、double
3)字符类型:char
二、分析uint8_t\uint_16_t\uint32_t\uint64_t
1、数据来源:这些数据类型中都带有_t, _t 表示这些数据类型是通过typedef定义的,而不是新的数据类型。也就是说,它们其实是我们已知的类型的别名。
2、typedef:typedef用来定义关键字或标识符的别名
3、使用原因:方便代码的维护。比如,在C中没有bool型,于是在一个软件中,一个程序员使用int,一个程序员使用short,会比较混乱,最好用一个typedef来定义一个统一的bool,每个程序员都可以用这个别名的bool。
不同的平台会有不同的字长,所以利用预编译和typedef可以方便的维护代码。
typedef unsigned char uint8_t;//将uint8_t别名为无符号字符型
4、定义:在C99标准中定义了这些数据类型,具体定义在:stdint.h中
定义类型如下:
typedef   signed          char int8_t;
typedef   signed short     int int16_t;
typedef   signed           int int32_t;
typedef   signed       __INT64 int64_t;
/* exact-width unsigned integer types */
typedef unsigned short     int uint16_t;
typedef unsigned           int uint32_t;
typedef unsigned       __INT64 uint64_t;
/* 7.18.1.2 */
/* smallest type of at least n bits */
/* minimum-width signed integer types */
typedef   signed          char int_least8_t;
typedef   signed short     int int_least16_t;
typedef   signed           int int_least32_t;
typedef   signed       __INT64 int_least64_t;
/* minimum-width unsigned integer types */
typedef unsigned          char uint_least8_t;
typedef unsigned short     int uint_least16_t;
typedef unsigned           int uint_least32_t;
typedef unsigned       __INT64 uint_least64_t;
/* 7.18.1.3 */
/* fastest minimum-width signed integer types */
typedef   signed           int int_fast8_t;
typedef   signed           int int_fast16_t;
typedef   signed           int int_fast32_t;
typedef   signed       __INT64 int_fast64_t;
/* fastest minimum-width unsigned integer types */
typedef unsigned           int uint_fast8_t;
typedef unsigned           int uint_fast16_t;
typedef unsigned           int uint_fast32_t;
typedef unsigned       __INT64 uint_fast64_t;
/* 7.18.1.4 integer types capable of holding object pointers */
#if __sizeof_ptr == 8
typedef   signed       __INT64 intptr_t;
typedef unsigned       __INT64 uintptr_t;
#else
typedef   signed           int intptr_t;
typedef unsigned           int uintptr_t;
#endif
/* 7.18.1.5 greatest-width integer types */
typedef   signed     __LONGLONG intmax_t;
typedef unsigned     __LONGLONG uintmax_t;
5、格式化输出:
1)uint16_t %hu
2)uint32_t %u
3)uint64_t %llu
6、uint8_t类型的输出:
uint8_t buf = 65;
printf("buf = %d",buf);//错误
printf("buf = %c",buf);//正确,打印出字符的ASCII码
作业粉碎机 发表于 2025-5-24 13:44 | 显示全部楼层
这些基本数据类型是C语言编程的基础,了解它们对于编写高效代码至关重要。
Carina卡 发表于 2025-6-8 10:59 | 显示全部楼层
在C语言中,基本数据类型(也称为内置数据类型)是构建程序的基础,用于定义变量、函数参数和返回值等
BetrayalNO 发表于 2025-6-8 12:09 | 显示全部楼层
整数类型,用于存储整数值,分为有符号(signed)和无符号(unsigned)两种
Allison8859 发表于 2025-6-8 13:15 | 显示全部楼层
注意:具体大小依赖编译器和平台(可通过 <limits.h> 查看)。
Estelle1999 发表于 2025-6-8 15:12 | 显示全部楼层
有符号字符char        -128 到 127,无符号字符unsigned char 0到255
Euphoriaxixi 发表于 2025-6-8 15:40 | 显示全部楼层
char默认是否有符号由编译器决定(通常是有符号的)。
Betty1299 发表于 2025-6-8 18:09 | 显示全部楼层
字符常量用单引号表示,如 'A'。用于存储小数或科学计数法表示的数值。
vevive 发表于 2025-6-8 19:37 | 显示全部楼层
浮点常量默认是 double,加 f 后缀表示 float(如 3.14f)。
EuphoriaV 发表于 2025-6-9 08:46 | 显示全部楼层
浮点数存在精度误差问题(如 0.1 + 0.2 != 0.3)。
across往事 发表于 2025-6-9 10:24 | 显示全部楼层
布尔用于逻辑判断,只有两个值:true 或 false。
Charlotte夏 发表于 2025-6-9 13:00 | 显示全部楼层
其实,布尔需包含头文件 <stdbool.h> 以使用 bool、true、false 的宏定义。
