[DemoCode下载] MG51一行代码进入最低功耗模式-掉电模式
946|0
 楼主| 598330983 发表于 2025-5-26 17:13 | 显示全部楼层 |阅读模式
  1. //***********************************************************************************************************
  2. //  File Function: MG51 power down code for test power down current, BOD disabled.
  3. //***********************************************************************************************************
  4. #include "MG51_SDCC.H"
  5. void main (void)
  6. {
  7. /* UART0 settting for printf function */
  8.     MODIFY_HIRC(HIRC_24);
  9.     Enable_UART0_VCOM_printf_24M_115200();
  10.     printf ("\n Test start ...");
  11. /* Quasi mode better for power down power comsuption (necessary) */
  12.     ALL_GPIO_QUASI_MODE;
  13.     P0=0;
  14.     P1=0;
  15.     P2=0;
  16. /* clock only for reference, real chip please don't output clock (necessary)*/
  17.     set_CKCON_CLOEN;
  18. /*MUST Disable BOD to low power (necessary) */
  19.     BOD_DISABLE;              //BOD enable power down current please check datasheet DC charactor.
  20. /* Real into power down mode (necessary) */
  21.     set_PCON_PD;
  22.     while(1);
  23.
  24. }
