LaunchPad之按键LED闪灯爽歪歪
2134|1
 楼主| gaoyang9992006 发表于 2012-6-12 17:50 | 显示全部楼层 |阅读模式
//默认一起闪烁,按下按键后交替闪烁,再按下又一起,……
#include <msp430g2452.h>
#define     BUTTON                BIT3
#define     LED_RED               BIT0
#define     LED_GREEN             BIT6
#define     LED_DIR               P1DIR
#define     BUTTON_DIR            P1DIR
#define     BUTTON_OUT            P1OUT
#define     LED_OUT               P1OUT
#define     BUTTON_REN            P1REN
#define     BUTTON_ON             (P1IN&BIT3)
#define     BUTTON_OFF           !(P1IN&BIT3)
#define     LED_RED_ON()            P1OUT|=BIT0
#define     LED_RED_OFF()           P1OUT&=~BIT0
#define     LED_GREEN_ON()          P1OUT|=BIT6
#define     LED_GREEN_OFF()         P1OUT&=~BIT6
volatile unsigned char i=0,flag=0;
void main(void)
WDTCTL = WDTPW + WDTHOLD;
   BUTTON_DIR &= ~BUTTON;
   LED_DIR    |= LED_RED+LED_GREEN;
   BUTTON_REN |= BUTTON;
      BUTTON_OUT  = BUTTON;
    while(1)
     /*通过按键改变选择标志位*/
     if(BUTTON_OFF)
        flag=!flag;
           while(BUTTON_OFF);
     if(flag)
       LED_RED_ON();
       i=10;
       while(i--)
       _delay_cycles(50000);
             LED_RED_OFF();
       LED_GREEN_ON();
       i=10;
       while(i--)
             LED_GREEN_OFF();
          else
              LED_OUT |= LED_RED+LED_GREEN;
              i=10;
              while(i--)
              LED_OUT ^= (LED_RED+LED_GREEN);
              i=10;
               while(i--)
 楼主| gaoyang9992006 发表于 2012-6-12 19:18 | 显示全部楼层
/**************变化一下,O(∩_∩)O哈哈~*******/
#define     BUTTON                BIT3
#define     BIT_SET(x , y)            x |= (y)
#define     BIT_CLR(x , y)            x &=~(y)
volatile unsigned char i=0,flag=1;
void main(void)
          BIT_CLR(BUTTON_DIR , BUTTON);
          BIT_SET(LED_DIR , LED_RED+LED_GREEN);
          BIT_SET(BUTTON_REN , BUTTON);
      BIT_SET(BUTTON_OUT , BUTTON);
    while(1)
     /*通过按键改变选择标志位*/
            if(BUTTON_OFF)
               flag=!flag;
           while(BUTTON_OFF);
            if(flag)
                     BIT_SET(LED_OUT , LED_RED);
                     i=10;
                     while(i--)
             BIT_CLR(LED_OUT , LED_RED);
                     BIT_SET(LED_OUT , LED_GREEN);
                     i=10;
                     while(i--)
             BIT_CLR(LED_OUT , LED_GREEN);
          else
                     BIT_SET(LED_OUT ,LED_RED+LED_GREEN);
                     i=10;
                     while(i--)
                     BIT_CLR(LED_OUT , LED_RED+LED_GREEN);
                     i=10;
                      while(i--)
