ubuntu下下载镜像文件环境搭建
1810|0
飞鹰嵌入式|  楼主 | 2012-6-12 23:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1/需要minicom
这个在环境搭建里面已经介绍了
下面介绍一种图形界面的
先在电脑上安装 cutecom:$sudo apt-get install cutecom
运行
$sudo cutecom
这个和xp下的超级终端一样,而且图形界面,比minicom容易上手。
2/需要dnw2,下面就是dnw2的安装
dnw2 安装说明:
dnw2.c 文件
/* dnw2 linux main file. This depends on libusb.
* Author:         feiying
* License:        GPL
#include <stdio.h>
#include <usb.h>
#include <errno.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#define QQ2440_SECBULK_IDVENDOR        0x5345
#define QQ2440_SECBULK_IDPRODUCT    0x1234
struct usb_dev_handle * open_port() {
    struct usb_bus *busses, *bus;
    usb_init();
    usb_find_busses();
    usb_find_devices();
    busses = usb_get_busses();
    for (bus = busses; bus; bus = bus->next) {
        struct usb_device *dev;
        for (dev = bus->devices; dev; dev = dev->next) {
            printf("idVendor:0x%x\t,ipProduct:0x%x\n",
                    dev->descriptor.idVendor, dev->descriptor.idProduct);
            if (QQ2440_SECBULK_IDVENDOR == dev->descriptor.idVendor
                    && QQ2440_SECBULK_IDPRODUCT == dev->descriptor.idProduct) {
                printf("Target usb device found!\n");
                struct usb_dev_handle *hdev = usb_open(dev);
                if (!hdev) {
                    perror("Cannot open device");
                } else {
                    if (0 != usb_claim_interface(hdev, 0)) {
                        perror("Cannot claim interface");
                        usb_close(hdev);
                        hdev = NULL;
                return hdev;
    printf("Target usb device not found!\n");
    return NULL;
void usage() {
    printf("Usage: dnw2 <file>\n\n");
unsigned char* prepare_write_buf(char *filename, unsigned int *len) {
    unsigned char *write_buf = NULL;
    struct stat fs;
    int fd = open(filename, O_RDONLY);
    if (-1 == fd) {
        perror("Cannot open file");
        return NULL;
    if (-1 == fstat(fd, &fs)) {
        perror("Cannot get file size");
        goto error;
    write_buf = (unsigned char*) malloc(fs.st_size + 10);
    if (NULL == write_buf) {
        perror("malloc failed");
        goto error;
    if (fs.st_size != read(fd, write_buf + 8, fs.st_size)) {
        perror("Reading file failed");
        goto error;
    printf("Filename : %s\n", filename);
    printf("Filesize : %d bytes\n", fs.st_size);
    *((u_int32_t*) write_buf) = 0x30000000; //download address
    *((u_int32_t*) write_buf + 1) = fs.st_size + 10; //download size;
    *len = fs.st_size + 10;
    return write_buf;
    error: if (fd != -1)
        close(fd);
    if (NULL != write_buf)
        free(write_buf);
    fs.st_size = 0;
    return NULL;
int main(int argc, char *argv[]) {
    if (2 != argc) {
        usage();
        return 1;
    struct usb_dev_handle *hdev = open_port();
    if (!hdev) {
        return 1;
    unsigned int len = 0;
    unsigned char* write_buf = prepare_write_buf(argv[1], &len);
        return 1;
    unsigned int remain = len;
    unsigned int towrite;
    printf("Writing data ...\n");
    while (remain) {
        towrite = remain > 512 ? 512 : remain;
        if (towrite != usb_bulk_write(hdev, 0x03, write_buf + (len - remain),
                towrite, 3000)) {
            perror("usb_bulk_write failed");
            break;
        remain -= towrite;
        printf("\r%d%\t %d bytes     ", (len - remain) * 100 / len, len
                - remain);
        fflush(stdout);
    if (0 == remain)
        printf("Done!\n");
    return 0;
把此文件保存成 dnw2.c
1, 安装  libusb 库
$ sudo apt-get install libusb-dev
2, 编译 dnw2.c 文件
$ gcc dnw2.c -o dnw2 -lusb
3, 把生成的 dnw2 移动到 /usr/bin 里面
$ sudo mv dnw2 /usr/bin
4,PC 链接 mini2440开发板,在终端里面运行
$ sudo minicom
打开 串口,按相应键进入 USB 传输
5,再开一个终端,输入
$ sudo dnw2 /work/路径/文件名
下载 OK
