[MM32生态] 【Mini-F5265-OB开发板试用测评】1、串口printf输出
1233|0
 楼主| Xiashiqi 发表于 2025-6-10 09:37 | 显示全部楼层 |阅读模式
测试串口printf输出。
一、硬件电路部分
开发板自带仿真器上有虚拟串口,插上USB仿真器可以找到串口设备号。
仿真器串口连接到MM32F5265芯片的PC10和PC11引脚(UART3功能)。
二、串口3功能
看手册串口3引脚的功能映射图
串口3映射到AF7,需要在程序中配置到此映射。
三、程序部分
3.1、usart.c
#include "main.h"
void init_usart(uint32_t Baudrate)
        GPIO_InitTypeDef GPIO_InitStruct;
        UART_InitTypeDef UART_InitStruct;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART3, ENABLE);
        UART_StructInit(&UART_InitStruct);
        UART_InitStruct.BaudRate      = Baudrate;
        UART_InitStruct.WordLength    = UART_WordLength_8b;
        UART_InitStruct.StopBits      = UART_StopBits_1;
        UART_InitStruct.Parity        = UART_Parity_No;
        UART_InitStruct.HWFlowControl = UART_HWFlowControl_None;
        UART_InitStruct.Mode          = UART_Mode_Tx;
        UART_Init(UART3, &UART_InitStruct);
        UART_Cmd(UART3, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
        GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_7);
        GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_7);
        GPIO_StructInit(&GPIO_InitStruct);
        GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_10;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
        GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOC, &GPIO_InitStruct);
        GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_11;
#if   defined (__ICCARM__)
#if   (__VER__ >= 9030001)
/* Files include */
#include <stddef.h>
#include <LowLevelIOInterface.h>
  * @brief  redefine __write function
  * @NOTE   for printf
  * @param  handle
  * @param  *buf
  * @param  bufSize
  * @retval nChars
size_t __write(int handle, const unsigned char *buf, size_t bufSize)
    size_t nChars = 0;
    /* Check for the command to flush all handles */
    if (-1 == handle)
        return (0);
    /* Check for stdout and stderr (only necessary if FILE descriptors are enabled.) */
    if ((_LLIO_STDOUT != handle) && (_LLIO_STDERR != handle))
        return (-1);
    for (/* Empty */; bufSize > 0; --bufSize)
        UART_SendData(UART2, *buf);
        while (RESET == UART_GetFlagStatus(UART2, UART_FLAG_TXC))
        ++buf;
        ++nChars;
    return (nChars);
#else
  * @brief  redefine fputc function
  * @note   for printf
  * @param  ch
  * @param  f
  * @retval ch
int fputc(int ch, FILE *f)
    UART_SendData(UART2, (uint8_t)ch);
    return (ch);
#endif
#elif defined (__GNUC__)
  * @note   for printf
  * @param  ch
  * @param  f
  * @retval ch
    UART_SendData(UART3, (uint8_t)ch);
    while (RESET == UART_GetFlagStatus(UART3, UART_FLAG_TXC))
    return (ch);
#else
  * @note   for printf
  * @param  ch
  * @param  f
  * @retval ch
    return (ch);
#endif
3.2、main.c
#include "main.h"
int main(void)
        SysTick_Init();
        init_usart(115200);
        init_led();
        while (1)
                led1_tog();
                led2_tog();
                SysTick_Delay_ms(100);
                printf("mm32F5265_ob_printf_test!\r\n");
四、运行结果
下载程序后,串口输出内容:
原文链接:https://blog.csdn.net/weixin_47569031/article/details/148534073
