[STM32F1] PWM组合3相模式,ADC触发问题
351|0
 楼主| 封存into 发表于 2025-6-16 03:00 | 显示全部楼层 |阅读模式
用通道6 PWM互补模式,后来增加了通道5无输出,中断触发。
中断回调函数TIM1_TRG_COM_TIM17_IRQRST
没有进入中断,进入中断会有个LED闪烁。
int main(void){  HAL_Init();  SystemClock_Config();   /* Compute the value of ARR register to generate signal frequency at 10 Khz */  mcuFreq = HAL_RCC_GetSysClockFreq();  timerPeriod = (uint32_t)((mcuFreq / 10000) - 1);    MX_GPIO_Init();  MX_TIM1_Init();  MX_ADC1_Init();  MX_USART1_UART_Init();  /* USER CODE BEGIN 2 */  __HAL_UART_FLUSH_DRREGISTER(&huart1);   __HAL_TIM_ENABLE_IT(&htim1,TIM_IT_UPDATE | TIM_IT_TRIGGER);   valBuf[0] = setDutyAsPercentage(20);  valBuf[1] = setDutyAsPercentage(50);  valBuf[2] = setDutyAsPercentage(80);  if(HAL_TIMEx_GroupChannel5(&htim1, (TIM_GROUPCH5_OC1REFC |\                                          TIM_GROUPCH5_OC2REFC |\                                          TIM_GROUPCH5_OC3REFC)) != HAL_OK)        Error_Handler();   if(HAL_TIM_PWM_Start_IT(&htim1, TIM_CHANNEL_1) != HAL_OK)         Error_Handler();  if(HAL_TIMEx_PWMN_Start_IT(&htim1, TIM_CHANNEL_1) != HAL_OK)        Error_Handler();  if(HAL_TIM_PWM_Start_IT(&htim1, TIM_CHANNEL_2) != HAL_OK)         Error_Handler();  if(HAL_TIMEx_PWMN_Start_IT(&htim1, TIM_CHANNEL_2) != HAL_OK)        Error_Handler();  if(HAL_TIM_PWM_Start_IT(&htim1, TIM_CHANNEL_3) != HAL_OK)         Error_Handler();  if(HAL_TIMEx_PWMN_Start_IT(&htim1, TIM_CHANNEL_3) != HAL_OK)        Error_Handler();  if(HAL_TIM_PWM_Start_IT(&htim1, TIM_CHANNEL_5) != HAL_OK)                Error_Handler(); //ADC Trigger   TIM1->CCR1 = valBuf[0];  TIM1->CCR2 = valBuf[1];  TIM1->CCR3 = valBuf[2];   HAL_UART_Receive_IT(&huart1, uartRxBuf, 1);    //if(HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED) != HAL_OK); Error_Handler();   //HAL_ADCEx_InjectedStart_IT(&hadc1);   while (1)  {   }}  // ---------------------------------------- stm32g4xx_it.c ----------------------------------------  //void TIM1_TRG_COM_TIM17_IRQHandler(void){        HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);        testCounter++;        HAL_TIM_IRQHandler(&htim1);}
