[AVR单片机] 求助:MEGA16在ICCAVR中的串口中断发送
3718|2
 楼主| dcp 发表于 2007-10-22 14:53 | 显示全部楼层 |阅读模式
//UART0 initialize
// desired baud rate: 2400
// actual: baud rate:2404 (0.2%)
// char size: 8 bit
// parity: Disabled
void uart0_init(void)
    UCSRB = 0x00; //disable while setting baud rate
    UCSRA = 0x00;
    UBRRL = 0x19; //set baud rate lo
    UBRRH = 0x00; //set baud rate hi
    //UCSRB = 0xD8;
    UCSRB = (1 << RXCIE) | (1 << TXCIE) | (1 << RXEN) | (1 << TXEN);
    UCSRC = BIT(URSEL) | 0x06;
#pragma interrupt_handler uart0_rx_isr:12
void uart0_rx_isr(void)
    //uart has received a character in UDR
    PutUartRx(UDR);//中数接收就OK!
unsigned char a = 1;
#pragma interrupt_handler uart0_tx_isr:14
void uart0_tx_isr(void)
    //character has been transmitted
    UDR = a;                         //这样发送数据错在哪里?串口助手收不到数据,
void main(void)
    init_devices();
    while(1)
        //putchar(a);这样查询发数就没有问题
请各位AVR高手帮忙,谢谢...
hotpower 发表于 2007-10-23 01:42 | 显示全部楼层
 楼主| dcp 发表于 2007-10-23 15:02 | 显示全部楼层
UCSRB &= ~(1 << UDRIE);
谢谢HOTPOWER
dcp
71
