[MM32生态] 基于rt-thread主线支持mm32f5265
7091|1
 楼主| renzheshengui 发表于 2025-7-10 15:43 | 显示全部楼层 |阅读模式
环境配置及启动芯片
Ubuntu20.04
env工具
官方有提供gcc的启动文件及链接文件,但移植到rt-thread的不能启动mm32f5265,然后修改了启动文件及链接文件;
启动文件修改的地方:
                .thumb_func
                .type    Reset_Handler, %function
                .globl   Reset_Handler
                .fnstart
Reset_Handler:
                ldr   sp, =_estack    /* set stack pointer */
               /* Copy the data segment initializers from flash to SRAM */
                 movs  r1, #0
                 b LoopCopyDataInit
CopyDataInit:
                   ldr r3, =_sidata
                   ldr r3, [r3, r1]
                   str r3, [r0, r1]
                   adds    r1, r1, #4
LoopCopyDataInit:
                   ldr r0, =_sdata
                   ldr r3, =_edata
                   adds    r2, r0, r1
                   cmp r2, r3
                   bcc CopyDataInit
                   ldr r2, =_sbss
                   b   LoopFillZerobss
               /* Zero fill the bss segment. */
FillZerobss:
                   movs    r3, #0
                   str r3, [r2], #4
LoopFillZerobss:
                   ldr r3, = _ebss
                   cmp r2, r3
                   bcc FillZerobss
               /* Call the clock system initialization function.*/
                   bl  SystemInit
               /* Call static constructors */
                   bl __libc_init_array
               /* Call the application's entry point.*/
                   bl  entry
                   bx   lr
LoopForever:
                   b LoopForever
                .fnend
                .size    Reset_Handler, . - Reset_Handler
链接文件主要修改的地方:
.text :
    . = ALIGN(4);
    KEEP(*(.vectors))
    . = ALIGN(4);
    *(.text)                        /* remaining code */
    *(.text.*)                      /* remaining code */
    *(.rodata)                      /* read-only data (constants) */
    *(.rodata*)
    *(.glue_7)
    *(.glue_7t)
    *(.gnu.linkonce.t*)
    /* section information for finsh shell */
    . = ALIGN(4);
    __fsymtab_start = .;
    KEEP(*(FSymTab))
    __fsymtab_end = .;
    . = ALIGN(4);
    __vsymtab_start = .;
    KEEP(*(VSymTab))
    __vsymtab_end = .;
    /* section information for initial. */
    . = ALIGN(4);
    __rt_init_start = .;
    KEEP(*(SORT(.rti_fn*)))
    __rt_init_end = .;
    . = ALIGN(4);
    PROVIDE(__ctors_start__ = .);
    KEEP (*(SORT(.init_array.*)))
    KEEP (*(.init_array))
    PROVIDE(__ctors_end__ = .);
    . = ALIGN(4);
    _etext = .;
  } > FLASH
适配rt-thread的控制台,从隔壁的mm32f327x里面复制一份drv_uart.c文件过来,添加uart3的支持,根据Mini-F5265-OB开发板的原理图修改uart3的引脚;
,修改Kconfig文件;
编译及烧录
pkgs --update
scons -j8
编译的log如下:
CC build/packages/mm32/HAL_Lib/Src/hal_wwdg.o
AS build/packages/mm32/System/startup_mm32f5260_gcc.o
CC build/packages/mm32/System/system_mm32f526x.o
LINK rtthread.elf
Memory region         Used Size  Region Size  %age Used
           FLASH:       83912 B       256 KB     32.01%
             RAM:        8656 B       112 KB      7.55%
arm-none-eabi-objcopy -O binary rtthread.elf rtthread.bin
arm-none-eabi-objcopy -O ihex rtthread.elf rtthread.hex
arm-none-eabi-size rtthread.elf
   text    data     bss     dec     hex filename
  83912    1988    6668   92568   16998 rtthread.elf
scons: done building targets.
使用pyocd工具进行烧录:
pyocd flash --erase chip --target MM32F5265E8PV --pack MindMotion.MM32F5260_DFP.0.2.0.pack rtthread.hex
运行效果
- RT -     Thread Operating System
/ | \     5.2.0 build Jan 22 2025 11:45:14
2006 - 2024 Copyright by RT-Thread team
msh >
RT-Thread shell commands:
at24cxx          - at24cxx eeprom function
adc              - adc [option]
pin              - pin [option]
clear            - clear the terminal screen
version          - show RT-Thread version information
list             - list objects
help             - RT-Thread shell help
ps               - List threads in the system
free             - Show the memory usage in the system
backtrace        - print backtrace of a thread
msh >list de
device
msh >list device
device           type         ref count
i2c1     I2C Bus              0
adc1     ADC Device           0
uart3    Character Device     2
pin      Pin Device           0
msh >
结尾
应经移植了uart、ADC、pin设备,由于年末没有时间移植其他的外设,等待工作没有那么忙在弄了,提前祝大家新年快乐,万事如意!
原文链接:https://blog.csdn.net/weixin_47569031/article/details/148957026
AdaMaYun 发表于 2025-7-31 17:30 | 显示全部楼层
