- void ADC_Init(void)
- GPIO_Config_T gpioConfig;
- ADC_Config_T adcConfig;
- ADC_CommonConfig_T adcCommonConfig;
- /* RCM Enable*/
- RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_GPIOA|RCM_AHB1_PERIPH_GPIOB|RCM_AHB1_PERIPH_GPIOC);
- /* GPIO Configuration */
- GPIO_ConfigStructInit(&gpioConfig);
- gpioConfig.pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6;
- gpioConfig.mode = GPIO_MODE_AN;
- gpioConfig.pupd = GPIO_PUPD_NOPULL;
- GPIO_Config(GPIOA, &gpioConfig);
- gpioConfig.pin = GPIO_PIN_0|GPIO_PIN_1;
- GPIO_Config(GPIOB, &gpioConfig);
- gpioConfig.pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3;
- GPIO_Config(GPIOC, &gpioConfig);
- RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1);
- RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC2);
- RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC3);
- ADC_Reset();
- /* ADC Common Configuration */
- adcCommonConfig.mode = ADC_MODE_TRIPLE_REGSIMULT;
- adcCommonConfig.prescaler = ADC_PRESCALER_DIV6;
- adcCommonConfig.accessMode = ADC_ACCESS_MODE_1;
- adcCommonConfig.twoSampling = ADC_TWO_SAMPLING_10CYCLES;
- ADC_CommonConfig(&adcCommonConfig);
- /* ADC Configuration */
- ADC_ConfigStructInit(&adcConfig);
- /* Set resolution*/
- adcConfig.resolution = ADC_RESOLUTION_12BIT;
- /* Set dataAlign*/
- adcConfig.dataAlign = ADC_DATA_ALIGN_RIGHT;
- /* Set scanDir*/
- adcConfig.scanConvMode = ENABLE;
- /* Set convMode continous*/
- adcConfig.continuousConvMode = ENABLE;
- /* Set extTrigEdge*/
- adcConfig.extTrigEdge = ADC_EXT_TRIG_EDGE_NONE;
- /* Set nbrOfConversion*/
- adcConfig.nbrOfChannel = 4;
- ADC_Config(ADC1, &adcConfig);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_0, 1, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_1, 2, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_2, 3, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_4, 4, ADC_SAMPLETIME_3CYCLES);
- ADC_Config(ADC2, &adcConfig);
- ADC_ConfigRegularChannel(ADC2, ADC_CHANNEL_5, 1, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC2, ADC_CHANNEL_6, 2, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC2, ADC_CHANNEL_8, 3, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC2, ADC_CHANNEL_9, 4, ADC_SAMPLETIME_3CYCLES);
- ADC_Config(ADC3, &adcConfig);
- ADC_ConfigRegularChannel(ADC3, ADC_CHANNEL_10, 1, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC3, ADC_CHANNEL_11, 2, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC3, ADC_CHANNEL_12, 3, ADC_SAMPLETIME_3CYCLES);
- ADC_ConfigRegularChannel(ADC3, ADC_CHANNEL_13, 4, ADC_SAMPLETIME_3CYCLES);
- ADC_EnableMultiModeDMARequest();
- /* Enable ADC*/
- ADC_Enable(ADC1);
- ADC_Enable(ADC2);
- ADC_Enable(ADC3);
- ADC_SoftwareStartConv(ADC1);
/* Set scanDir*/
双重或三重 ADC 模式,ADC1 默认为主ADC,其他默认为从 ADC,只需要ADC1开始采样,其他ADC就也能工作。接下来是DMA的配置
查看用户手册,ADC1在DMA2的通道0 数据流0.根据这个进行配置
- void DMA_Init(uint32_t* Buf)
- /* DMA Configure */
- DMA_Config_T dmaConfig;
- /* Enable DMA clock */
- RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_DMA2);
- /* size of buffer*/
- dmaConfig.bufferSize = 12;
- /* set memory Data Size*/
- dmaConfig.memoryDataSize = DMA_MEMORY_DATA_SIZE_HALFWORD;
- /* Set peripheral Data Size*/
- dmaConfig.peripheralDataSize = DMA_PERIPHERAL_DATA_SIZE_HALFWORD;
- /* Enable Memory Address increase*/
- dmaConfig.memoryInc = DMA_MEMORY_INC_ENABLE;
- /* Disable Peripheral Address increase*/
- dmaConfig.peripheralInc = DMA_PERIPHERAL_INC_DISABLE;
- /* Reset Circular Mode*/
- dmaConfig.loopMode = DMA_MODE_CIRCULAR;
- /* set priority*/
- dmaConfig.priority = DMA_PRIORITY_HIGH;
- /* read from peripheral*/
- dmaConfig.dir = DMA_DIR_PERIPHERALTOMEMORY;
- /* Set memory Address*/
- dmaConfig.memoryBaseAddr = (uint32_t)Buf;
- /* Set Peripheral Address*/
- dmaConfig.peripheralBaseAddr = (uint32_t)&ADC->CDATA;
- dmaConfig.channel = DMA_CHANNEL_0;
- dmaConfig.fifoMode = DMA_FIFOMODE_ENABLE;
- dmaConfig.fifoThreshold = DMA_FIFOTHRESHOLD_HALFFULL;
- dmaConfig.peripheralBurst = DMA_PERIPHERALBURST_SINGLE;
- dmaConfig.memoryBurst = DMA_MEMORYBURST_SINGLE;
- DMA_Config(DMA2_Stream0, &dmaConfig);
- NVIC_EnableIRQRequest(DMA2_STR0_IRQn, 0x01, 0x01);
- /* Clear DMA TF flag*/
- DMA_ClearIntFlag(DMA2_Stream0, DMA_INT_TCI**0);
- /* Enable DMA Interrupt*/
- DMA_EnableInterrupt(DMA2_Stream0,DMA_INT_TCI**);
- DMA_Enable(DMA2_Stream0);
开启DMA中断,可以在每轮采样完成后进行数据处理
- void DMA_IRQHandler(void)
- if(DMA_ReadIntFlag(DMA2_Stream0,DMA_INT_TCI**0) != RESET)
- APM_MINI_LEDToggle(LED2);
- ADC1_CH0_ConvertedValue = (float)DMA_DualConvertedValue[0]/4095*3.3f;
- ADC2_CH5_ConvertedValue = (float)DMA_DualConvertedValue[1]/4095*3.3f;
- ADC3_CH10_ConvertedValue = (float)DMA_DualConvertedValue[2]/4095*3.3f;
- ADC1_CH1_ConvertedValue = (float)DMA_DualConvertedValue[3]/4095*3.3f;
- ADC2_CH6_ConvertedValue = (float)DMA_DualConvertedValue[4]/4095*3.3f;
- ADC3_CH11_ConvertedValue = (float)DMA_DualConvertedValue[5]/4095*3.3f;
- ADC1_CH2_ConvertedValue = (float)DMA_DualConvertedValue[6]/4095*3.3f;
- ADC2_CH8_ConvertedValue = (float)DMA_DualConvertedValue[7]/4095*3.3f;
- ADC3_CH12_ConvertedValue = (float)DMA_DualConvertedValue[8]/4095*3.3f;
- ADC1_CH4_ConvertedValue = (float)DMA_DualConvertedValue[9]/4095*3.3f;
- ADC2_CH9_ConvertedValue = (float)DMA_DualConvertedValue[10]/4095*3.3f;
- ADC3_CH13_ConvertedValue = (float)DMA_DualConvertedValue[11]/4095*3.3f;
- DMA_ClearIntFlag(DMA2_Stream0,DMA_INT_TCI**0);
最后可以使用串口打印,输出采的电压。
- int main(void)
- USART_Config_T usartConfigStruct;
- /* USART configuration */
- USART_ConfigStructInit(&usartConfigStruct);
- usartConfigStruct.baudRate = 115200;
- usartConfigStruct.mode = USART_MODE_TX_RX;
- usartConfigStruct.parity = USART_PARITY_NONE;
- usartConfigStruct.stopBits = USART_STOP_BIT_1;
- usartConfigStruct.wordLength = USART_WORD_LEN_8B;
- usartConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
- APM_MINI_LEDInit(LED2);
- /* COM1 init*/
- APM_MINI_COMInit(COM1, &usartConfigStruct);
- DMA_Init((uint32_t*)DMA_DualConvertedValue);
- ADC_Init();
- while (1)
- Delay(0x1FFFFF);
- printf("\r\nADC CH0: ADC1 Voltage = %f V \r\n", ADC1_CH0_ConvertedValue);
- printf("ADC CH1: ADC1 Voltage = %f V \r\n", ADC1_CH1_ConvertedValue);
- printf("ADC CH2: ADC1 Voltage = %f V \r\n", ADC1_CH2_ConvertedValue);
- printf("ADC CH4: ADC1 Voltage = %f V \r\n", ADC1_CH4_ConvertedValue);
- printf("ADC CH5: ADC2 Voltage = %f V \r\n", ADC2_CH5_ConvertedValue);
- printf("ADC CH6: ADC2 Voltage = %f V \r\n", ADC2_CH6_ConvertedValue);
- printf("ADC CH8: ADC2 Voltage = %f V \r\n", ADC2_CH8_ConvertedValue);
- printf("ADC CH9: ADC2 Voltage = %f V \r\n", ADC2_CH9_ConvertedValue);
- printf("ADC CH10: ADC2 Voltage = %f V \r\n", ADC3_CH10_ConvertedValue);
- printf("ADC CH11: ADC2 Voltage = %f V \r\n", ADC3_CH11_ConvertedValue);
- printf("ADC CH12: ADC2 Voltage = %f V \r\n", ADC3_CH12_ConvertedValue);
- printf("ADC CH13: ADC2 Voltage = %f V \r\n", ADC3_CH13_ConvertedValue);
将PA0接到高电平,查看串口打印的就是正确的了。
APM32F4xx_SDK_V1.4-3ADC.zip
(9.83 MB, 下载次数: 3)
