[单片机资料] 飞思卡尔单片机驱动HT1621
5207|0
 楼主| 比神乐 发表于 2025-7-21 18:33 | 显示全部楼层 |阅读模式
代码:
  1. #include <hidef.h>      /* common defines and macros */
  2. #include "derivative.h"      /* derivative-specific definitions */
  3. #define LED PORTB
  4. #define LED_dir DDRB
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. #define DA_1  PORTB |= 0X10//RS置1
  8. #define DA_0  PORTB &= 0XEF//RS置0
  9. #define WR_1  PORTB |= 0X04//RS置1
  10. #define WR_0  PORTB &= 0XFB//RS置0
  11. #define CS_1  PORTB |= 0X01//RS置1
  12. #define CS_0  PORTB &= 0XFE//RS置0
  13. unsigned char data=0x01;
  14. #define Smg_a 0x80
  15. #define Smg_b 0x40
  16. #define Smg_c 0x20
  17. #define Smg_d 0x01
  18. #define Smg_e 0x02
  19. #define Smg_f 0x08
  20. #define Smg_g 0x04
  21. #define Smg_dp 0x10
  22. #define Bmp0Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
  23. #define Bmp1Map Smg_b | Smg_c
  24. #define Bmp2Map Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
  25. #define Bmp3Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
  26. #define Bmp4Map Smg_b | Smg_c | Smg_f | Smg_g
  27. #define Bmp5Map Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
  28. #define Bmp6Map Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  29. #define Bmp8Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  30. #define Bmp9Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
  31. #define Bmp7Map Smg_a | Smg_b | Smg_c
  32. #define BmpAMap Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
  33. #define BmpBMap Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  34. #define BmpCMap Smg_a | Smg_d | Smg_e | Smg_f
  35. #define BmpDMap Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
  36. #define BmpEMap Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
  37. #define BmpFMap Smg_a | Smg_e | Smg_f | Smg_g
  38. const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
  39. unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
  40. unsigned int i;
  41. void COMMAND_HT1621(unsigned char comm)
  42. {
  43. //unsigned char i;
  44. CS_0;
  45.   ;
  46. WR_0;
  47.    ;
  48. for(i=0;i<3;i++)//???
  49. {
  50. if((0x04<<i)&0x04)
  51.                                                    DA_1; //100
  52. else
  53.                                     DA_0;
  54. ;
  55. WR_0;
  56.   ;
  57. WR_1;
  58.   ;
  59. }
  60. for(i=0;i<9;i++)//?????
  61. {
  62.     if((comm<<i)&0x80) DA_1; //100
  63.     else DA_0;
  64.     ;
  65.     WR_0;
  66.      ;
  67.     WR_1;
  68.      ;
  69. }
  70. CS_1;
  71.   ;
  72. }
  73. void HT1621_Display(void)
  74. {
  75. //unsigned char i;
  76. CS_0;//??CS
  77.    ;
  78. WR_0;
  79.    ;
  80. for(i=0;i<3;i++) //???
  81. {
  82.     if((0x05<<i)&0x04) DA_1;
  83.     else DA_0;
  84.      ;
  85.     WR_0;
  86.     ;
  87.     WR_1;
  88.     ;
  89. }
  90. for(i=0;i<6;i++) //???
  91. {
  92.     if((20<<i)&0x20) DA_1;//20?? SEG??
  93.     else DA_0;
  94.      ;
  95.     WR_0;
  96.      ;
  97.     WR_1;
  98.      ;
  99. }
  100. for(i=0;i<8;i++) //???
  101. {
  102.     if((DpyNum[5]<<i)&0x80)
  103.                                                    DA_1;
  104.     else DA_0;
  105.     ;
  106.     WR_0;
  107.     ;
  108.     WR_1;
  109.     ;
  110. }
  111. for(i=0;i<8;i++) //???
  112. {
  113. if((DpyNum[4]<<i)&0x80)DA_1;
  114. else DA_0;
  115.   ;
  116. WR_0;
  117.   ;
  118. WR_1;
  119.   ;
  120. }
  121. for(i=0;i<8;i++) //???
  122. {
  123. if((DpyNum[3]<<i)&0x80) DA_1;
  124. else DA_0;
  125.   ;
  126. WR_0;
  127. ;
  128. WR_1;
  129. ;
  130. }
  131. for(i=0;i<8;i++) //???
  132. {
  133. if((DpyNum[2]<<i)&0x80)DA_1;
  134. else DA_0;
  135. ;
  136. WR_0;
  137. ;
  138. WR_1;
  139. ;
  140. }
  141. for(i=0;i<8;i++) //???
  142. {
  143. if((DpyNum[1]<<i)&0x80)DA_1;
  144. else DA_0;
  145. ;
  146. WR_0;
  147. ;
  148. WR_1;
  149.   ;
  150. }
  151. for(i=0;i<8;i++) //???
  152. {
  153. if((DpyNum[0]<<i)&0x80) DA_1;
  154. else DA_0;
  155. ;
  156. WR_0;
  157. ;
  158. WR_1;
  159. ;
  160. }
  161. CS_1;
  162. }
  163. void LCD_Init(void)
  164. {
  165. COMMAND_HT1621(0x01);//SYS EN
  166. COMMAND_HT1621(0x03);//LCD ON
  167. COMMAND_HT1621(0x29);//4 COM牋1/3 BIAS
  168. HT1621_Display(); //clear screen
  169. }
  170. /*************************************************************/
  171. /*                        延时函数                           */
  172. /*************************************************************/
  173. void delay(void)
  174. {
  175.   unsigned int i,j;
  176.   for(j=0;j<2;j++)
  177.   for(i=0;i<60000;i++)
  178.   ;
  179. }
  180. /*************************************************************/
  181. /*                          主函数                           */
  182. /*************************************************************/
  183. void main(void) {
  184.         //DisableInterrupts;
  185. // LED_dir=0xff;       //设置为输出
  186. // LED=~data;          //点亮LED1
  187. //        EnableInterrupts;
  188.     DDRB=0XFF;
  189.     delay();
  190.    LCD_Init();
  191. DpyNum[0] = Smg_a|Smg_d|Smg_g;//"?"
  192. DpyNum[1] = SegCode[2];
  193. DpyNum[2] = SegCode[4];
  194. DpyNum[3] = SegCode[6];
  195. DpyNum[4] = SegCode[8];
  196. DpyNum[5] = SegCode[0];
  197. HT1621_Display();
  198.   for(;;)
  199.   {
  200.
  201.
  202.   }
  203. }
效果图:
附件喘不上来
