[APM32F4] 【APM32F402R Micro-EVB开发板测评】+OLED屏驱动显示
768|2
 楼主| jinglixixi 发表于 2025-7-22 17:16 | 显示全部楼层 |阅读模式
APM32F402R Micro-EVB开发板是一款近于最小系统得开发板,为其添加相应的外设,可用起到丰富其羽翼的作用。这里就利用闲置I2C接口来为其配置一个OLED显示屏,闲置的I2C电路如图1所示。
1214153edf4e5ad55d55f70951f9c4da
图1  闲置I2C电路
该闲置I2C电路所使用的引脚为PB8和PB9,这里就用它与OLED屏的对应引脚连接。
在使用I2C进行硬件驱动前,先以模拟的方式来驱动该显示屏。
对OLED屏所用引脚的配置函数为:
  1. void BOARD_OLED_Config()
  3. GPIO_Config_T GPIO_ConfigStruct = {0U};
  4. RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_GPIOB);
  5. GPIO_ConfigStruct.pin = GPIO_PIN_8|GPIO_PIN_9;
  6. GPIO_ConfigStruct.mode = GPIO_MODE_OUT_PP;
  7. GPIO_ConfigStruct.speed = GPIO_SPEED_50MHz;
  8. GPIO_Config(GPIOB, &GPIO_ConfigStruct);
  9. }
实现高低电平输出的语句定义为:
#define  OLED_SCLK_Clr()    GPIOB->BC = GPIO_PIN_8
#define  OLED_SCLK_Set()    GPIOB->BSC = GPIO_PIN_8
#define  OLED_SDIN_Clr()    GPIOB->BC = GPIO_PIN_9
#define  OLED_SDIN_Set()    GPIOB->BSC = GPIO_PIN_9
此外,为较好地控制时序关系,还使用SysTick配置了一个起短延时作用的函数,其内容为:
  1. void delay_u(uint32_t delay)
  3. delay = 0xff*delay;
  4. while(delay--);
  5. }
模拟I2C发送字节数据的函数为:
  1. void Write_IIC_Byte(unsigned char IIC_Byte)
  3. unsigned char i;
  4. unsigned char m,da;
  5. da=IIC_Byte;
  6. OLED_SCLK_Clr();
  7. for(i=0;i<8;i++)
  8. {
  9. m=da;
  10. m=m&0x80;
  11. if(m==0x80)
  12. {
  13. OLED_SDIN_Set();
  14. }
  15. else
  16. OLED_SDIN_Clr();
  17. da=da<<1;
  18. delay_u(3);
  19. OLED_SCLK_Set();
  20. delay_u(3);
  21. OLED_SCLK_Clr();
  22. delay_u(3);
  23. }
  24. }
对显示屏的初始化函数为:
  1. void OLED_Init(void)
  3. Write_IIC_Command(0xAE);
  4. Write_IIC_Command(0x40);
  5. Write_IIC_Command(0xb0);
  6. Write_IIC_Command(0xc8);
  7. Write_IIC_Command(0x81);
  8. Write_IIC_Command(0xff);
  9. Write_IIC_Command(0xa1);
  10. Write_IIC_Command(0xa6);
  11. Write_IIC_Command(0xa8);
  12. Write_IIC_Command(0x1F);
  13. Write_IIC_Command(0xd3);
  14. Write_IIC_Command(0x00);
  15. Write_IIC_Command(0xd5);
  16. Write_IIC_Command(0xf0);
  17. Write_IIC_Command(0xd9);
  18. Write_IIC_Command(0x22);
  19. Write_IIC_Command(0xda);
  20. Write_IIC_Command(0x02);
  21. Write_IIC_Command(0x8d);
  22. Write_IIC_Command(0x14);
  23. Write_IIC_Command(0xdb);
  24. Write_IIC_Command(0x49);
  25. Write_IIC_Command(0xaf);
  26. }
实现清除屏幕的函数为:
  1. void OLED_Clear(void)
  3. uint8_t i,n;
  4. for(i=0;i<8;i++)
  5. {
  6. OLED_WR_Byte (0xb0+i,OLED_CMD);
  7. OLED_WR_Byte (0x00,OLED_CMD);
  8. OLED_WR_Byte (0x10,OLED_CMD);
  9. for(n=0;n<128;n++) OLED_WR_Byte(0,OLED_DATA);
  10. }
  11. }
发送字符的函数为:
  1. void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
  3. unsigned char c=0,i=0;
  4. c=chr-' ';
  5. if(x>Max_Column-1){x=0;y=y+2;}
  6. if(Char_Size ==16)
  7. {
  8. OLED_Set_Pos(x,y);
  9. for(i=0;i<8;i++)
  10. OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
  11. OLED_Set_Pos(x,y+1);
  12. for(i=0;i<8;i++)
  13. OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
  14. }
  15. else
  16. {
  17. OLED_Set_Pos(x,y);
  18. for(i=0;i<6;i++)
  19. OLED_WR_Byte(F6x8[c][i],OLED_DATA);
  20. }
  21. }
显示字符串的函数为:
  1. void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
  3. unsigned char j=0;
  4. while (chr[j]!='\0')
  5. {OLED_ShowChar(x,y,chr[j],Char_Size);
  6. x+=8;
  7. if(x>120){x=0;y+=2;}
  8. j++;
  9. }
  10. }
实现显示测试的主程序为:
  1. int main(void)
  3. SystemCoreClockUpdate();
  4. BOARD_LED_Config(LED2);
  5. BOARD_LED_Config(LED3);
  6. SysTick_Config(SystemCoreClock / 1000);
  7. BOARD_OLED_Config();
  8. OLED_Init();
  9. OLED_Clear();
  10. OLED_ShowString(0,0,"APM32F402",16);
  11. while (1)
  12. {
  13. BOARD_LED_Toggle(LED2);
  14. BOARD_LED_Toggle(LED3);
  15. Delay(1000);
  16. }
  17. }
经程序的编译和下载,其显示效果如图2所示,说明功能正常。
692108050ca7d86810f4a564f42e84ef
图2 显示效果
FrostShimmer 发表于 2025-7-23 10:54 | 显示全部楼层
这颗M4内核的MCU驱动OLED看来是绰绰有余啊
 楼主| jinglixixi 发表于 2025-7-23 11:22 | 显示全部楼层
没问题,但对于双色OLED屏来说可能会无法显示。
