[STM32F1] 向某个特定的flash地址0x0807F800写入一些数据
761|0
 楼主| 小库里 发表于 2025-8-8 12:57 | 显示全部楼层 |阅读模式
我想在STM32Cube IDE中向某个特定的flash地址0x0807F800写入一些数据,我使用了下面提函数进行读写。当我编译代码时,编译成功,但我看到地址0x0807F800是空白的。
nt32_t Flash_Write_Data (uint32_t StartPageAddress, uint32_t *Data, uint16_t numberofwords)
static FLASH_EraseInitTypeDef EraseInitStruct;
uint32_t PAGEError;
int sofar=0;
/* Unlock the Flash to enable the flash control register access *************/
  HAL_FLASH_Unlock();
  /* Erase the user Flash area*/
uint32_t StartPage = StartPageAddress;
uint32_t EndPageAdress = StartPageAddress + numberofwords*4;
uint32_t EndPage = EndPageAdress;
  /* Fill EraseInit structure*/
  EraseInitStruct.TypeErase  = FLASH_TYPEERASE_PAGES;
  EraseInitStruct.Page = StartPage;
  EraseInitStruct.NbPages   = ((EndPage - StartPage)/FLASH_PAGE_SIZE) +1;
  if (HAL_FLASHEx_Erase(&EraseInitStruct, &PAGEError) != HAL_OK)
   /*Error occurred while page erase.*/
return HAL_FLASH_GetError ();
  /* Program the user Flash area word by word*/
  while (sofar<numberofwords)
   if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_FAST, StartPageAddress, Data[sofar]) == HAL_OK)
   StartPageAddress += 4; // use StartPageAddress += 2 for half word and 8 for double word
   sofar++;
   else
    /* Error occurred while writing data in Flash memory*/
  /* Lock the Flash to disable the flash control register access (recommended
   to protect the FLASH memory against possible unwanted operation) *********/
  HAL_FLASH_Lock();
  return 0;
void Flash_Read_Data (uint32_t StartPageAddress, uint32_t *RxBuf, uint16_t numberofwords)
while (1)
*RxBuf = *(__IO uint32_t *)StartPageAddress;
RxBuf++;
if (!(numberofwords--)) break;
uint32_t data[]={0X11111111,0X22222222};
int main(void)
Flash_Write_Data ( 0x0807F800 ,data, 2);
Flash_Read_Data( 0x0807F800 , Rx_Data, 3);
