为什么at32f421使用DMA接收的串口数据不完整,请大佬们指教
887|0
Hdj123 发表于 2025-8-12 14:30 | 显示全部楼层 |阅读模式
void usart_init(void)
    GPIO_InitType GPIO_InitStructure;
    USART_InitType USART_InitStructure;
    NVIC_InitType NVIC_InitStructure;
    DMA_InitType DMA_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_GPIOA, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_USART2, ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_DMA1, ENABLE);
    GPIO_PinAFConfig(GPIOA, GPIO_PinsSource2, GPIO_AF_1);
    GPIO_PinAFConfig(GPIOA, GPIO_PinsSource3, GPIO_AF_1);
    GPIO_InitStructure.GPIO_Pins = GPIO_Pins_2 | GPIO_Pins_3; // USART2 TX/RX
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
    GPIO_InitStructure.GPIO_OutType = GPIO_OutType_PP;
    GPIO_InitStructure.GPIO_Pull = GPIO_Pull_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure); // USART2 GPIO config
    USART_InitStructure.USART_BaudRate = 921600;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART2, &USART_InitStructure); // USART2 config
    //USART_INTConfig(USART2, USART_INT_RDNE, ENABLE);
        USART_Cmd(USART2, ENABLE); // USART2 enable
    USART_INTConfig(USART2, USART_INT_IDLEF, ENABLE);
        USART_DMACmd(USART2, USART_DMAReq_Rx, ENABLE);
    DMA_Reset(DMA1_Channel5);
    DMA_DefaultInitParaConfig(&DMA_InitStructure);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&USART2 ->DT;
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)dma_rx;
    DMA_InitStructure.DMA_Direction = DMA_DIR_PERIPHERALSRC;
    DMA_InitStructure.DMA_BufferSize = sizeof(dma_rx);
    DMA_InitStructure.DMA_PeripheralInc = DMA_PERIPHERALINC_DISABLE;
    DMA_InitStructure.DMA_MemoryInc = DMA_MEMORYINC_ENABLE;
    DMA_InitStructure.DMA_PeripheralDataWidth = DMA_PERIPHERALDATAWIDTH_BYTE;
    DMA_InitStructure.DMA_MemoryDataWidth = DMA_MEMORYDATAWIDTH_BYTE;
    DMA_InitStructure.DMA_Mode = DMA_MODE_CIRCULAR;//DMA_MODE_NORMAL;//
    DMA_InitStructure.DMA_Priority = DMA_PRIORITY_HIGH;
    DMA_InitStructure.DMA_MTOM = DMA_MEMTOMEM_DISABLE;
    DMA_Init(DMA1_Channel5, &DMA_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
        DMA_ChannelEnable(DMA1_Channel5, ENABLE); // 启用DMA接收
}void USART2_IRQHandler(void)
#if 1
    if( USART_GetITStatus(USART2, USART_INT_IDLEF) != RESET)
//                USART_ClearITPendingBit(USART2, USART_INT_IDLEF);
//                USART_ReceiveData(USART2);
                USART2->STS;
                USART2->DT;
        DMA_ChannelEnable(DMA1_Channel5, DISABLE);
                receiver.data_length = sizeof(dma_rx) - DMA_GetCurrDataCounter(DMA1_Channel5);
        DMA_SetCurrDataCounter(DMA1_Channel5, sizeof(dma_rx));
                receiver.frame_complete = 1;
                key_test ++;
#endif
    //处理错误标志
    if(USART_GetFlagStatus(USART2, USART_FLAG_ORERR) != RESET)
        USART_ClearFlag(USART2, USART_FLAG_ORERR);
        uint8_t data = USART_ReceiveData(USART2);
