[开发工具] BMP561与 BQ27Z561 ESD测试报告对比,哪个更高?
294|0
Reli-eng-z 发表于 2025-8-15 23:18 | 显示全部楼层 |阅读模式
BMP561 BQ27Z561 ESD测试报告对比,哪个更高?
最近有朋友给我推荐了极海的BMP561产品,ESD设计的比TI好,我不相信,于是就从朋友那里拿到了样品,对ESD/LU进行了实测,结果极海ESD更高,具体高在哪里呢?听我一一道来:
第一:BMP561-HBM高
实验1HBM人体放电模型测试实验
测试对象:1.Geehy_BMP561单芯片ESD方案,2.BQ27Z561单芯片ESD方案
测试方法:在MK2机台,根据芯片数据手册梳理所有管脚耐压值,电源、IO属性形成pinlist。梳理完pinlist,按照如下组合分配管脚,
HBM  test
All Other Pins To VSS(±)500V~8000V,Step 500V
All Other Pins To BAT(6V)(±)500V~8000V,Step 500V
IO To IO(±)500V~8000V,Step 500V
根据表格pin组合以及步进,pin组合是根据JS-001标准实施,MK2机台执行测试。
调试好自动化测试程序
需设置的参数为(以下来源于数据手册,可公开):
Pin Group
Type
Pin(s)
VSS
GROUND
B2
BAT(6V)
POWER
D2
IP(2.1V)_TS
INPUT
B1
IP(6.3V)_SRN
INPUT
C1
IP(6.3V)_BAT_SNS
INPUT
C2
IP(6.3V)_SRP
INPUT
D1
IP(6V)_CE
INPUT
D3
IO(6V)_INT
OUTPUT
A1
IO(6V)_PULS
OUTPUT
A2
IO(6V)_SDA/HDQ
OUTPUT
A3
IO(6V)_SCL
OUTPUT
B3
IO(6V)_NU
OUTPUT
C3
IO
A1,A2,A3,B1,B3,C1,C2,C3,D1,D3
测试结果如下:
1. Geehy_BMP561单芯片HBM结果(ESD结果会有三方实验室报告,可以对外):
Group
Pin
Pin Name
Zap Level
Criteria
BAT(6V)
D2
BAT
±8000V
Passed
IP(2.1V)_TS
B1
TS
±8000V
Passed
IP(6V)_CE
D3
CE
±8000V
Passed
IP(6.3V)_BAT_SNS
C2
BAT_SNS
±8000V
Passed
IP(6.3V)_SRP
D1
SRP
±8000V
Passed
IP(6.3V)_SRN
C1
SRN
±8000V
Passed
IO(6V)_INT
A1
INT
±8000V
Passed
IO(6V)_PULS
A2
PULS
±8000V
Passed
IO(6V)_SCL
B3
SCL
±8000V
Passed
IO(6V)_SDA/HDQ
A3
SDA/HDQ
±8000V
Passed
IO(6V)_NU
C3
NU
±8000V
Passed
VSS
B2
VSS
±8000V
Passed
Group
Pin
Pin Name
Zap Level
Criteria
Zap Level
Criteria
BAT(6V)
D2
BAT
±7000V
CC (after)
±7000V
CC (after)
IP(2.1V)_TS
B1
TS
±7000V
Passed
±7000V
Passed
IP(6V)_CE
D3
CE
±7000V
Passed
±7000V
Passed
IP(6.3V)_BAT_SNS
C2
BAT_SNS
±7000V
Passed
±7000V
Passed
IP(6.3V)_SRP
D1
SRP
±7000V
Passed
±7000V
Passed
IP(6.3V)_SRN
C1
SRN
±7000V
Passed
±7000V
Passed
IO(6V)_INT
A1
INT
±7000V
Passed
±7000V
Passed
IO(6V)_PULS
A2
PULS
±7000V
Passed
±7000V
Passed
IO(6V)_SCL
B3
SCL
±7000V
Passed
±7000V
Passed
IO(6V)_SDA/HDQ
A3
SDA/HDQ
±7000V
Passed
±7000V
Passed
IO(6V)_NU
C3
NU
±7000V
Passed
±7000V
Passed
VSS
B2
VSS
±7000V
Passed
±7000V
Passed
结果上看,打了3HBM1颗可以直达8KV,另两颗6.5KV,那么按照水桶效应,整体判定为±6.5KV
2. BQ27Z561单芯片HBM结果:
Group
Pin
Pin Name
Zap Level
Criteria
Zap Level
Criteria
Zap Level
Criteria
BAT(6V)
D2
BAT
3000V
CC (after Zap)
3000V
CC (after Zap)
3000V
CC (after Zap)
VSS
B2
VSS
3000V
CC (Zap to BAT(6V))
3000V
CC (Zap to BAT(6V))
3000V
CC (Zap to BAT(6V))
IP(2.1V)_TS
B1
TS
±3000V
Passed
±3000V
Passed
±3000V
Passed
IP(6V)_CE
D3
CE
±3000V
Passed
±3000V
Passed
±3000V
Passed
IP(6.3V)_BAT_SNS
C2
BAT_SNS
±3000V
Passed
±3000V
Passed
±3000V
Passed
IP(6.3V)_SRP
D1
SRP
±3000V
Passed
±3000V
Passed
±3000V
Passed
IP(6.3V)_SRN
C1
SRN
±3000V
Passed
±3000V
Passed
±3000V
Passed
IO(6V)_INT
A1
INT
±3000V
Passed
±3000V
Passed
±3000V
Passed
IO(6V)_PULS
A2
PULS
±3000V
Passed
±3000V
Passed
±3000V
Passed
IO(6V)_SCL
B3
SCL
±3000V
Passed
±3000V
Passed
±3000V
Passed
IO(6V)_SDA/HDQ
A3
SDA/HDQ
±3000V
Passed
±3000V
Passed
±3000V
Passed
IO(6V)_NU
C3
NU
±3000V
Passed
±3000V
Passed
±3000V
Passed
结果上看,打了3HBM3±2.5KV,着实比BMP561低了±4KV.
实验2CDM带电器件模型测试(ESD结果会有三方实验室报告,可以对外)
1Geehy_BMP561单芯片CDM结果
Test Model: CDM TEST
ESD Sensitivity Passed: ±2000V
Unit
Test condition
Sample Quantity
Passed Volts
IV Result Description
C1
C2
C3
CDM 250V~2000V,Step 250V FOR ALL 12 BALLS
±2000V
PASS
2、BQ27Z561单芯片CDM结果:
Unit
Test condition
Sample Quantity
Passed Volts
C1
C2
C3
±2000V
PASS
CDM二者无差别。
第二:BMP561-LU PASS
实验3LU闩锁效应(ESD结果会有三方实验室报告,可以对外)
1Geehy_BMP561单芯片LU结果
Test Model: LATCH-UP test 125C
Unit
Trigger Mode
Test Pin Group
Sample Quantity
Tested Result
V or I Limits
L1
L2
L3
I-Test(positive)
IP(2.1V)_TS
PASS +200mA
+3.150V
IO(2.1V)_NU
PASS +200mA
+3.150V
IP(6V)_CE
PASS +200mA
+9.000V
IO(6V)_INT
PASS +200mA
+9.000V
IO(6V)_PULS
PASS +200mA
+9.000V
IO(6V)_SCL
PASS +200mA
+9.000V
IO(6V)_SDA/HDQ
PASS +200mA
+9.000V
IP(6.3V)_BAT_SNS
PASS +200mA
+9.450V
IP(6.3V)_SRP
PASS +200mA
+9.450V
IP(6.3V)_SRN
PASS +200mA
+9.450V
I-Test(negative)
IP(2.1V)_TS
PASS -200mA
-1.050V
IO(2.1V)_NU
PASS -200mA
-1.050V
IP(6V)_CE
PASS -200mA
-3.000V
IO(6V)_INT
PASS -200mA
-3.000V
IO(6V)_PULS
PASS -200mA
-3.000V
IO(6V)_SCL
PASS -200mA
-3.000V
IO(6V)_SDA/HDQ
PASS -200mA
-3.000V
IP(6.3V)_BAT_SNS
PASS -200mA
-3.150V
IP(6.3V)_SRP
PASS -200mA
-3.150V
IP(6.3V)_SRN
PASS -200mA
-3.150V
Vsupply Over-voltage test
BAT(6V)
PASS +9.000 V
+600mA
2BQ27Z561单芯片LU结果:
Test Model: LATCH-UP test@125C
Unit
Trigger Mode
Test Pin Group
Sample Quantity
Tested Result
V or I Limits
L3
L4
I-Test(positive)
IP(2.1V)_TS
PASS +200mA
+3.15V
IP(6V)_CE
PASS +200mA
+9.0V
IP(6.3V)_BAT_SNS
PASS +200mA
+9.45V
IP(6.3V)_SRP
PASS +200mA
+9.45V
IP(6.3V)_SRN
PASS +200mA
+9.45V
IO(6V)_INT
PASS +200mA
+9.0V
IO(6V)_PULS
PASS +200mA
+9.0V
IO(6V)_SCL
PASS +200mA
+9.0V
IO(6V)_SDA/HDQ
PASS +200mA
+9.0V
IO(2.1V)_NU
PASS +200mA
+3.15V
I-Test(negative)
IP(2.1V)_TS
PASS -200mA
-1.05V
IP(6V)_CE
PASS -200mA
-2.750V
IP(6.3V)_BAT_SNS
PASS -200mA
-3.15V
IP(6.3V)_SRP
PASS -200mA
-3.15V
IP(6.3V)_SRN
FAIL -200mA
-3.15V
IO(6V)_INT
PASS -200mA
-3.0V
IO(6V)_PULS
PASS -200mA
-3.0V
IO(6V)_SCL
PASS -200mA
-3.0V
IO(6V)_SDA/HDQ
PASS -200mA
-3.0V
IO(6V)_NU
PASS -200mA
-1.05V
BAT(6V)
PASS +9.0 V
+600mA
总结
1、从整体的ESD测试结果来看,对比BQ27Z561单芯片ESD结果,BMP561HBMBQ27Z561的高±4KV,LU 125°高温下BMP561过了,反而TI没过,这一点要为国产芯片点赞!
从未来芯片应用上,抗ESD能力明显强于 BQ27Z561,CDM测试结果一致,两者比较接近
2、单从HBM/LU来看,BMP561抗静电能力远远优于BQ27Z561,可以支持用户应用于ESD要求高的场景。如:
1、HBM耐压高:HBM测试电压越高(如8KV vs. 4KV),芯片在人体静电放电场景下的防护能力越强,减少因ESD导致的失效风险。
2、LU抗干扰强:更高的LU耐压(如100mA vs. 50mA)意味着芯片在电源噪声或瞬态干扰下更不易触发闩锁效应,提升系统稳定性
极海产品通过各类认证是芯片进入各自对应领域的必备门槛,需从设计、制造到测试全链条协同优化。
“如果您正在寻找高可靠性的芯片,欢迎联系极海半导体有限公司获取免费样品(www.geehy.comm)。”
“关注Geehy极海半导体 公众号,回复‘认证’获取完整认证指南。”
