[研电赛技术支持] GD32F407 I2S DMA如何只停数据保持时钟输出
1344|8
lishang4650 发表于 2025-8-26 10:31 | 显示全部楼层 |阅读模式
目前代码停dma后时钟也一起停止了,如何实现只停数据,保持时钟输出
  1. void i2s_gpio_config(void)
  3.     /* configure I2S1 and I2S1_ADD pins: I2S2_WS(PA15), I2S2_CK(PC10), I2S2_SD(PD6), I2S2_ADD_SD(PC11) */
  4.         gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_6);//CLK
  5.     gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_25MHZ, GPIO_PIN_6);
  6.         gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_15);//WS
  7.     gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_25MHZ, GPIO_PIN_15);
  8.     gpio_mode_set(GPIOC, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10 | GPIO_PIN_11);
  9.     gpio_output_options_set(GPIOC, GPIO_OTYPE_PP, GPIO_OSPEED_25MHZ, GPIO_PIN_10 | GPIO_PIN_11);
  10.
  11.     gpio_af_set(GPIOA, GPIO_AF_6, GPIO_PIN_15);
  12.     gpio_af_set(GPIOC, GPIO_AF_6, GPIO_PIN_10);
  13.     gpio_af_set(GPIOC, GPIO_AF_5, GPIO_PIN_11);
  14.     gpio_af_set(GPIOD, GPIO_AF_5, GPIO_PIN_6);
  15. }
  16. /*!
  17.     \brief      configure different peripheral clocks
  18.     \param[in]  none
  19.     \param[out] none
  20.     \retval     none
  21. */
  22. void i2s_rcu_config(void)
  23. {
  24.     /* enable GPIOA clock */
  25.     rcu_periph_clock_enable(RCU_GPIOA);
  26.     /* enable GPIOB clock */
  27.     rcu_periph_clock_enable(RCU_GPIOC);
  28.     /* enable GPIOI clock */
  29.     rcu_periph_clock_enable(RCU_GPIOD);
  30.     /* enable SPI2/I2S2 clock */
  31.     rcu_periph_clock_enable(RCU_SPI2);
  32.     /* enable DMA0 clock */
  33.     rcu_periph_clock_enable(RCU_DMA0);
  34. }
  35. /*!
  36.     \brief      configure the SPI peripheral
  37.     \param[in]  none
  38.     \param[out] none
  39.     \retval     none
  40. */
  41. void i2s_spi_config(void)
  42. {
  43.     spi_i2s_deinit(SPI2);
  44.     /* configure I2S2 and I2S2_ADD */
  45.     i2s_init(SPI2, I2S_MODE_MASTERTX, I2S_STD_PHILLIPS, I2S_CKPL_LOW);
  46.     i2s_psc_config(SPI2, I2S_AUDIOSAMPLE_48K, I2S_FRAMEFORMAT_DT16B_CH16B, I2S_MCKOUT_DISABLE);
  47.     i2s_full_duplex_mode_config(I2S2_ADD, I2S_MODE_MASTERTX, I2S_STD_PHILLIPS, I2S_CKPL_LOW, I2S_FRAMEFORMAT_DT16B_CH16B);
  48. }
  49. void i2s_dma_config(void)
  50. {
  51.     dma_single_data_parameter_struct dma_init_struct;
  52.     dma_single_data_para_struct_init(&dma_init_struct);
  53.         dma_deinit(DMA0, DMA_CH5);
  54.         dma_init_struct.periph_addr                   = (uint32_t)&SPI_DATA(SPI2);
  55.         dma_init_struct.memory0_addr            = (uint32_t)i2s2_Audiobuffer1;
  56.         dma_init_struct.direction                   = DMA_MEMORY_TO_PERIPH;
  57.         dma_init_struct.periph_memory_width = DMA_PERIPH_WIDTH_16BIT;
  58.         dma_init_struct.priority                    = DMA_PRIORITY_LOW;
  59.         dma_init_struct.number                           = I2S_AUDIO_SIZE;
  60.         dma_init_struct.periph_inc                   = DMA_PERIPH_INCREASE_DISABLE;
  61.         dma_init_struct.memory_inc                   = DMA_MEMORY_INCREASE_ENABLE;
  62.         dma_init_struct.circular_mode           = DMA_CIRCULAR_MODE_DISABLE;
  63.         dma_single_data_mode_init(DMA0, DMA_CH5, &dma_init_struct);
  64.         dma_channel_subperipheral_select(DMA0, DMA_CH5, DMA_SUBPERI0);
  65.         dma_circulation_disable(DMA0, DMA_CH5);
  66.         dma_interrupt_enable(DMA0, DMA_CH5, DMA_INT_FTF);
  67.         nvic_irq_enable(DMA0_Channel5_IRQn, 0, 0);  // 使能DMA中断
  68.         //dma_interrupt_enable(DMA0, DMA_CH5, DMA_INT_FTF);
  69. //    /* configure I2S2_ADD transmit DMA */
  70. //    dma_deinit(DMA0, DMA_CH5);
  71. //    dma_init_struct.periph_addr  = (uint32_t)&SPI_DATA(I2S2_ADD);
  72. //    dma_init_struct.memory0_addr = (uint32_t)i2s2_txbuffer;
  73. //    dma_init_struct.direction    = DMA_MEMORY_TO_PERIPH;
  74. //    dma_init_struct.priority     = DMA_PRIORITY_LOW;
  75. //    dma_single_data_mode_init(DMA0, DMA_CH5, &dma_init_struct);
  76. //    dma_channel_subperipheral_select(DMA0, DMA_CH5, DMA_SUBPERI2);
  77. //
  78.     /* configure SPI2 receive DMA */
  79. //    dma_deinit(DMA0, DMA_CH0);
  80. //    dma_init_struct.periph_addr  = (uint32_t)&SPI_DATA(SPI2);
  81. //    dma_init_struct.memory0_addr = (uint32_t)i2s2_rxbuffer;
  82. //    dma_init_struct.direction    = DMA_PERIPH_TO_MEMORY;
  83. //    dma_init_struct.priority     = DMA_PRIORITY_ULTRA_HIGH;
  84. //    dma_single_data_mode_init(DMA0, DMA_CH0, &dma_init_struct);
  85. //    dma_channel_subperipheral_select(DMA0, DMA_CH0, DMA_SUBPERI0);
  86. }
  87. void DMA0_Channel5_IRQHandler(void) {
  88.     // 检查传输完成标志
  89.     if(dma_interrupt_flag_get(DMA0, DMA_CH5, DMA_INT_FLAG_FTF)) {
  90.         dma_interrupt_flag_clear(DMA0, DMA_CH5, DMA_INT_FLAG_FTF);
  91.
  92.         // 停止当前DMA通道
  93.         dma_channel_disable(DMA0, DMA_CH5);
  94.
  95.         // 切换缓冲区
  96.         if(I2S_Buffer_Index == 0)
  97.                 {
  98.                    I2S_Buffer1_playdone = 1;
  99.             // Buffer1传输完成,切换到Buffer2
  100.             dma_memory_address_config(DMA0, DMA_CH5,DMA_MEMORY_0, (uint32_t)i2s2_Audiobuffer2);
  101.
  102.             I2S_Buffer_Index = 1;
  103.         }
  104.                 else
  105.                 {
  106.                     I2S_Buffer2_playdone = 1;
  107.             // Buffer2传输完成,切换到Buffer1
  108.             dma_memory_address_config(DMA0, DMA_CH5, DMA_MEMORY_0,(uint32_t)i2s2_Audiobuffer1);
  109.             I2S_Buffer_Index = 0;
  110.         }
  111.
  112.         // 重新设置传输数量并启动DMA
  113.         dma_transfer_number_config(DMA0, DMA_CH5, I2S_AUDIO_SIZE);
  114.         dma_channel_enable(DMA0, DMA_CH5);
  115.     }
  116. }
  117. void I2S2_Init(void)
  118. {
  119.     /* enable peripheral clock */
  120.     i2s_rcu_config();
  121.     /* configure GPIO */
  122.     i2s_gpio_config();
  123.     /* configure DMA */
  124.     i2s_dma_config();
  125.     /* configure I2S */
  126.     i2s_spi_config();
  127.     /* enable I2S and I2S_ADD*/
  128.     i2s_enable(SPI2);
  129.     i2s_enable(I2S2_ADD);
  130.     /* enable DMA channel */
  131.         //spi_dma_enable(SPI2, SPI_DMA_TRANSMIT);
  132.     //dma_channel_enable(DMA0, DMA_CH5);
  133. }
  134. void I2S_DMA_Start(void)
  135. {
  136.
  137.         //i2s_enable(SPI2);
  138.         //i2s_enable(I2S2_ADD);
  139.         //dma_memory_address_config(DMA0, DMA_CH5, DMA_MEMORY_0,(uint32_t)i2s2_txbuffer);
  140.         //dma_transfer_number_config(DMA0, DMA_CH5, 96);
  141.         //nvic_irq_enable(DMA0_Channel5_IRQn, 0, 0);        // 使能DMA中断
  142.         spi_dma_enable(SPI2, SPI_DMA_TRANSMIT);
  143.     dma_channel_enable(DMA0, DMA_CH5);
  144.         //delay_1ms(1);
  145.         Play_Config();
  146. }
  147. void I2S_DMA_Stop(void)
  148. {
  149.         //Exit_Play_Mode();
  150.         //delay_1ms(1);
  151.         spi_dma_disable(SPI2, SPI_DMA_TRANSMIT);
  152.         dma_channel_disable(DMA0, DMA_CH5);
  153.         //nvic_irq_disable(DMA0_Channel5_IRQn);        // 使能DMA中断
  154.         dma_interrupt_flag_clear(DMA0, DMA_CH5, DMA_INT_FTF);
  155.         dma_interrupt_flag_clear(DMA0, DMA_CH5, DMA_INT_HTF);
  156.         //delay_1ms(10);
  157.         //Enter_Sleep_Mode();
  158.         //I2S2_Init();
  159.         //CLD8684_Init();
  160.         //Play_Config();
  161.         // 等待DMA完全停止
  162.                 //while(dma_flag_get(DMA1, DMA_CH4, DMA_FLAG_CHEN));
  163.         //while((DMA_CHCTL(DMA0,DMA_CH5) & DMA_CHXCTL_CHEN) != 0);
  164.                 // 强制保持I2S2使能(防止意外关闭)
  165.                 if((SPI_CTL1(SPI2) & SPI_I2SCTL_I2SEN) == 0) {
  166.                         i2s_enable(SPI2);
  167.                 }
  168. }
海滨消消 发表于 2025-8-26 16:39 | 显示全部楼层
仅停止DMA,保持 I2S运行。
duo点 发表于 2025-8-26 16:39 | 显示全部楼层
仅停止 DMA,不关闭 I2S
onlycook 发表于 2025-8-26 16:41 | 显示全部楼层
发送空数据保持时钟。
七毛钱 发表于 2025-8-26 16:41 | 显示全部楼层
检查 I2S配置基 I2S模式
内政奇才 发表于 2025-8-26 16:42 | 显示全部楼层
尝试仅停止 DMA,检查时钟是否仍然输出。
如果时钟停止,改用 发送空数据 的方式保持时钟。
用 逻辑分析仪 验证时钟行为。
 楼主| lishang4650 发表于 2025-8-27 09:07 | 显示全部楼层
用 逻辑分析仪 验证时钟行为。
用示波器看了,只停DMA,I2S_CLK也停了
