[研电赛技术支持] GD32F3x0 ADC注入通道采集软件触发4个通道
1756|0
Zhiniaocun 发表于 2025-9-5 16:24 | 显示全部楼层 |阅读模式
1. 代码
//main.c
#include "gd32f3x0.h"
#include "systick.h"
#include <stdio.h>
#include "main.h"
#include "gd32f350r_eval.h"
#include "adc.h"
#include "bsp_gpio.h"
    \brief      configure the different system clocks
    \param[in]  none
    \param[out] none
    \retval     none
void rcu_config(void)
    /* enable GPIOC clock */
    rcu_periph_clock_enable(RCU_GPIOA);
    /* enable ADC clock */
    rcu_periph_clock_enable(RCU_ADC);
    /* enable timer1 clock */
    rcu_periph_clock_enable(RCU_TIMER1);
    /* config ADC clock */
    rcu_adc_clock_config(RCU_ADCCK_APB2_DIV6);
    \brief      configure the GPIO peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void gpio_config(void)
    /* config the GPIO as analog mode */
    gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4);
    \brief      configure the TIMER peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void timer_config(void)
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    /* TIMER1 configuration */
    timer_initpara.prescaler         = 8399U;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 9999U;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0U;
    timer_init(TIMER1, &timer_initpara);
    /* CH0 configuration in PWM mode1 */
    timer_ocintpara.ocpolarity  = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
    timer_channel_output_config(TIMER1, TIMER_CH_0, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER1, TIMER_CH_0, 3999U);
    timer_channel_output_mode_config(TIMER1, TIMER_CH_0, TIMER_OC_MODE_PWM1);
    timer_channel_output_shadow_config(TIMER1, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
    \brief      configure the ADC peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void adc_config(void)
    /* ADC scan mode enable */
    adc_special_function_config(ADC_SCAN_MODE, ENABLE);                //屏蔽后,只转换一个通道
    /* ADC trigger config */
    adc_external_trigger_source_config(ADC_INSERTED_CHANNEL, ADC_EXTTRIG_INSERTED_NONE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC_DATAALIGN_RIGHT);
    /* ADC channel length config */
    adc_channel_length_config(ADC_INSERTED_CHANNEL, 4U);
    /* ADC inserted channel config */
    adc_inserted_channel_config(0U, ADC_CHANNEL_1, ADC_SAMPLETIME_55POINT5);
    adc_inserted_channel_config(1U, ADC_CHANNEL_2, ADC_SAMPLETIME_55POINT5);
    adc_inserted_channel_config(2U, ADC_CHANNEL_3, ADC_SAMPLETIME_55POINT5);
    adc_inserted_channel_config(3U, ADC_CHANNEL_4, ADC_SAMPLETIME_55POINT5);
    /* ADC external trigger enable */
    adc_external_trigger_config(ADC_INSERTED_CHANNEL, ENABLE);
    /* enable ADC interface */
    adc_enable();
    delay_1ms(1U);
    /* ADC calibration and reset calibration */
    adc_calibration_enable();
uint16_t buf[4];
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    /* system clocks configuration */
    rcu_config();
    /* systick configuration */
    systick_config();
    /* GPIO configuration */
    gpio_config();
    /* TIMER configuration */
    timer_config();
    /* ADC configuration */
    adc_config();
    /* enable TIMER1 */
    timer_enable(TIMER1);
    while(1) {
      adc_software_trigger_enable(ADC_INSERTED_CHANNEL);
      while(!adc_flag_get(ADC_FLAG_EOIC));
      adc_flag_clear(ADC_FLAG_EOIC);
      buf[0] = adc_inserted_data_read(ADC_INSERTED_CHANNEL_0);
      buf[1] = adc_inserted_data_read(ADC_INSERTED_CHANNEL_1);
      buf[2] = adc_inserted_data_read(ADC_INSERTED_CHANNEL_2);
      buf[3] = adc_inserted_data_read(ADC_INSERTED_CHANNEL_3);
      delay_1ms(500);
//gd32f3x0_it.c
#include "gd32f3x0_it.h"
#include "main.h"
void SysTick_Handler(void)
    delay_decrement();
//systick.c
volatile static uint32_t delay;
    \brief      configure systick
    \param[in]  none
    \param[out] none
    \retval     none
void systick_config(void)
    /* setup systick timer for 1000Hz interrupts */
    if(SysTick_Config(SystemCoreClock / 1000U)) {
        /* capture error */
        while(1) {
    /* configure the systick handler priority */
    NVIC_SetPriority(SysTick_IRQn, 0x00U);
    \brief      delay a time in milliseconds
    \param[in]  count: count in milliseconds
    \param[out] none
    \retval     none
void delay_1ms(uint32_t count)
    delay = count;
    while(0U != delay) {
    \brief      delay decrement
    \param[in]  none
    \param[out] none
    \retval     none
void delay_decrement(void)
    if(0U != delay) {
        delay--;
2. 效果
版权声明:本文为CSDN博主「lljss2020」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/lljss1980/article/details/149809073
