[STM32G0] STM32CubeIDE提示“An error has occured. See the log file null”
490|0
zhouyou99 发表于 2025-9-6 13:17 | 显示全部楼层 |阅读模式
se, AN, The, UL, EE, or
我和同事使用的电脑上都无法启动 STM32CubeIDE 1.8.0。
弹出以下错误对话框:
由于没有日志文件,调试该问题非常困难。
从命令行启动 stm32cubeidec.exe 会显示以下输出:
H:\>C:\ST\STM32CubeIDE_1.8.0\STM32CubeIDE\stm32cubeidec.exe
java.lang.IllegalStateException: Error initializing storage for Equinox container.
        at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:110)
        at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:53)
        at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:46)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:315)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:251)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.base/java.lang.reflect.Method.invoke(Method.java:566)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
Caused by: java.io.FileNotFoundException: C:\ST\STM32CubeIDE_1.8.0\STM32CubeIDE\configuration\org.eclipse.osgi\.manager\.fileTableLock (Access is denied)
        at java.base/java.io.RandomAccessFile.open0(Native Method)
        at java.base/java.io.RandomAccessFile.open(RandomAccessFile.java:345)
        at java.base/java.io.RandomAccessFile.<init>(RandomAccessFile.java:259)
        at java.base/java.io.RandomAccessFile.<init>(RandomAccessFile.java:214)
        at org.eclipse.osgi.internal.location.Locker_JavaNio.lock(Locker_JavaNio.java:40)
        at org.eclipse.osgi.storagemanager.StorageManager.lock(StorageManager.java:403)
        at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:716)
        at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:2270)
        at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:2287)
        at org.eclipse.osgi.storage.Storage.<init>(Storage.java:252)
        at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:180)
        at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:108)
        ... 11 more
