[STM32L0] STM32CubeIDE ISR在CCM SRAM中运行
510|2
cutfall 发表于 2025-9-14 22:51 | 显示全部楼层 |阅读模式
我根据应用笔记AN 4996进行修改,应用程序工作不正常。
是否有使用STM32CubeIDE配置的示例项目,让中断例程在CCM RAM中运行?
//AT linker cmd file
MEMORY
RAM  (xrw)  : ORIGIN = 0x20000000,  LENGTH = 96K
FLASH  (rx)  : ORIGIN = 0x8000000,  LENGTH = 512K
CCMRAM (xrw) : ORIGIN = 0x10000000, LENGTH = 32K
  /*--- New CCMRAM linker section definition ---*/
_siccmram = LOADADDR(.ccmram);
  /* CCMRAM section */
  .ccmram :
  . = ALIGN(4);
  _sccmram = .; /* define a global symbols at ccmram start */
  *(.ccmram)
  *(.ccmram*)
  . = ALIGN(4);
  _eccmram = .; /* define a global symbols at ccmram end */
  } >CCMRAM AT> FLASH
/*--- End of CCMRAM linker section definition ---*/
//At startup code:
Reset_Handler:
ldr  r0, =_estack
mov  sp, r0     /* set stack pointer */
/* Copy the data segment initializers from flash to SRAM */
ldr r0, =_sdata
ldr r1, =_edata
ldr r2, =_sidata
movs r3, #0
b LoopCopyDataInit
CopyDataInit:
ldr r4, [r2, r3]
str r4, [r0, r3]
adds r3, r3, #4
LoopCopyDataInit:
adds r4, r0, r3
cmp r4, r1
bcc CopyDataInit
/* Copy from flash to CCMRAM */
ldr r0, =_sccmram
ldr r1, =_eccmram
ldr r2, =_siccmram
movs r3, #0
b LoopCopyCcmInit
CopyCcmInit:
ldr r4, [r2, r3]
str r4, [r0, r3]
adds r3, r3, #4
LoopCopyCcmInit:
adds r4, r0, r3
cmp r4, r1
bcc CopyCcmInit
/* End of copy to CCMRAM */
/* Zero fill the bss segment. */
ldr r2, =_sbss
ldr r4, =_ebss
movs r3, #0
b LoopFillZerobss
FillZerobss:
str r3, [r2]
adds r2, r2, #4
LoopFillZerobss:
cmp r2, r4
bcc FillZerobss
/* Call the clock system intitialization function.*/
  bl SystemInit
/* Call static constructors */
  bl __libc_init_array
/* Call the application's entry point.*/
bl main
LoopForever:
  b LoopForever
.size Reset_Handler, .-Reset_Handler
powerantone 发表于 2025-9-15 15:18 | 显示全部楼层
链接脚本需要修正一下。
cr315 发表于 2025-9-15 17:19 | 显示全部楼层
将中断例程放到CCMRAM。
