[STM32F7] stm32f745vet 无法通过 STM32CubeIDE 烧录
463|0
唐纳德d 发表于 2025-10-7 02:31 | 显示全部楼层 |阅读模式
使用 STM32 ST-LINK Utility ,一切正常,我可以烧录 hex 文件,固件也能运行。
但如果我通过 STM32CubeIDE进入调试,总是出现这个错误:以下是控制台文本。
Error in final launch sequence:
Error in initializing ST-LINK device.
Reason: (1) Failed to connect to device. Please check power and cabling to target.
STMicroelectronics ST-LINK GDB server. Version 5.3.2
Starting server with the following options:
        Persistent Mode            : Disabled
        Logging Level              : 1
        Listen Port Number         : 61234
        Status Refresh Delay       : 15s
        Verbose Mode               : Disabled
        SWD Debug                  : Enabled
Waiting for debugger connection...
Debugger connected
Failed #5
                       STM32CubeProgrammer v2.2.0
Log output file:   C:\Users\LAB2-R~1\AppData\Local\Temp\STM32CubeProgrammer_a05448.log
ST-LINK SN  : 55FF6C067282575133492167
ST-LINK FW  : V2J34S7
Voltage     : 3.19V
Error: ST-LINK error (DEV_TARGET_RESET_ERR)
Encountered Error when opening C:\ST\STM32CubeIDE_1.0.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_1.1.0.201910081157\tools\bin\STM32_Programmer_CLI.exe
Error in STM32CubeProgrammer
Debugger connection lost.
Shutting down...
我试了几个编程器和几个相同的mcu,结果都一样——IDE 总是报这个错误。
