[STM32F4] STM32F4 - HardFault_Handler / HAL_TIMEOUT 错误
513|0
石榴大王 发表于 2025-10-7 15:36 | 显示全部楼层 |阅读模式
我有两块 STM32F446RE  PCB,遇到了以下问题。
测试板仅运行简单的 LED 闪烁程序:
板 1:
程序有时会进入 HardFault,情况如下:
HCLK 时钟 = 82 MHz
HSI RC = 16 MHz
程序在 HardFault_Handler 处停止,情况如下:
HCLK 时钟 >= 83 MHz
HSI RC = 16 MHz
使用 HSE = 16 MHz 时也会出现同样的情况。
板 2:
HCLK 时钟 = 75 MHz
HSI RC = 16 MHz
HCLK 时钟 >= 76 MHz
HSI RC = 16 MHz
此处使用 HSE 时,在调用 SystemClock_Config() 时会返回 HAL_TIMEOUT 错误,在 HAL_RCC_OscConfig 中调试时得到以下数值:
tickstart = 101
HAL_GetTick() -> uwTick 在 101 处停止
外部晶振连接了 22pF 的电容。
附上了main.c 文件。
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 82;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
        HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_10);
        HAL_Delay(500);
        HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_9);
        HAL_Delay(500);
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
