[STM32F4] arm_gcc_link脚本没有传递正确的fnVector表地址。
449|0
石榴大王 发表于 2025-10-17 22:29 | 显示全部楼层 |阅读模式
arm_gcc_link脚本(32F407VGT6U)没有传递正确的fnVector表地址。使用下面的脚本,MCU没有复位到正确的位置。fnVector表位于ROM地址0x08010000
OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
/* Internal Memory Map*/
MEMORY
        rom (rx) : ORIGIN = 0x08010000, LENGTH = 1024k - 64k
        ram (rwx) : ORIGIN = 0x20000000, LENGTH = 128k
        ram1 (rwx) : ORIGIN = 0x10000000, LENGTH = 64k
_estack = ORIGIN(ram) + LENGTH(ram) -8; /* -8 keeps older bootloaders (before 2.0.2-HAL) happy */
SECTIONS
        .text :
  PROVIDE(_linker_isr_loc = .);
KEEP(*(.isr_vector))
*(.text*)
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*crtbegin?.o(.ctors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*crtbegin?.o(.dtors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.rodata*)
KEEP(*(.eh_fram e*))
        } > rom
        .ARM.extab :
*(.ARM.extab* .gnu.linkonce.armextab.*)
        } > rom
        __exidx_start = .;
        .ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
        } > rom
        __exidx_end = .;
        __etext = .;
        /* _sidata is used in coide startup code */
        _sidata = __etext;
        .data :
__data_start__ = .;
/* _sdata is used in coide startup code */
_sdata = __data_start__;
*(vtable)
*(.data*)
. = ALIGN(4);
/* preinit data */
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP(*(.preinit_array))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(4);
/* init data */
PROVIDE_HIDDEN (__init_array_start = .);
KEEP(*(SORT(.init_array.*)))
KEEP(*(.init_array))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(4);
/* finit data */
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP(*(SORT(.fini_array.*)))
KEEP(*(.fini_array))
PROVIDE_HIDDEN (__fini_array_end = .);
KEEP(*(.jcr*))
. = ALIGN(4);
/* All data end */
__data_end__ = .;
/* _edata is used in coide startup code */
_edata = __data_end__;
        } > ram AT > rom
        .bss :
. = ALIGN(4);
__bss_start__ = .;
_sbss = __bss_start__;
*(.bss*)
*(COMMON)
. = ALIGN(4);
__bss_end__ = .;
_ebss = __bss_end__;
        } > ram
        .heap (COPY):
__end__ = .;
_end = __end__;
end = __end__;
*(.heap*)
__HeapLimit = .;
        } > ram
        /* .stack_dummy section doesn't contains any symbols. It is only
        * used for linker to calculate size of stack sections, and assign
        * values to stack symbols later */
        .co_stack (NOLOAD):
. = ALIGN(8);
*(.co_stack .co_stack.*)
        } > ram
        .ccm (NOLOAD) : {
. = ALIGN(4);
_sccmram = .;
*(.ccm)
. = ALIGN(4);
_eccmram = .;
        }>ram1
        /* Set stack top to end of ram , and stack limit move down by
        * size of stack_dummy section */
        __StackTop = ORIGIN(ram ) + LENGTH(ram );
        __StackLimit = __StackTop - SIZEOF(.co_stack);
        PROVIDE(__stack = __StackTop);
        /* Check if data + heap + stack exceeds ram limit */
        ASSERT(__StackLimit >= __HeapLimit, "region ram overflowed with stack")
