[STM32F3] STM32F302C8HSE晶振无法工作
593|13
我的牙白 发表于 2025-10-20 22:21 | 显示全部楼层 |阅读模式
使用St Cube IDE 给STM32F302C8创建了新项目。在调试程序时发现HSE晶振无法工作(Systick始终为0)。代码最终陷入死循环循环。
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
海滨消消 发表于 2025-10-21 16:42 | 显示全部楼层
晶振可能没正确焊接或坏了
classroom 发表于 2025-10-21 17:43 | 显示全部楼层
晶振负载电容不匹配?
cr315 发表于 2025-10-21 18:44 | 显示全部楼层
晶振未使能?检查PH0/OSC_IN和PH1/OSC_OUT引脚是否正确连接。
duo点 发表于 2025-10-21 19:46 | 显示全部楼层
时钟配置可能不适合具体硬件
flycamelaaa 发表于 2025-10-21 20:46 | 显示全部楼层
检查晶振是否正确焊接
jcky001 发表于 2025-10-21 21:47 | 显示全部楼层
检查晶振旁边的负载电容是否正确
onlycook 发表于 2025-10-21 22:48 | 显示全部楼层
用示波器查看晶振引脚是否有振荡信号
powerantone 发表于 2025-10-21 17:48 | 显示全部楼层
先使用内部高速时钟运行看看
powerantone 发表于 2025-10-21 17:10 | 显示全部楼层
HSE启动超时时间可能不足导致的
probedog 发表于 2025-10-21 19:20 | 显示全部楼层
时钟配置顺序不当?
solty 发表于 2025-10-21 18:11 | 显示全部楼层
检查晶振电源和地是否干净
spicy 发表于 2025-10-21 20:29 | 显示全部楼层
可以用CubeMX重新生成时钟配置代码
stormwind123 发表于 2025-10-21 16:52 | 显示全部楼层
考虑换晶振或用外部时钟信号源测试
