ZCC5069-具有功率限制功能的9V至80V热插拔控制器 替代LM5069
1351|0
HPT-Lt 发表于 2025-10-21 17:37 | 显示全部楼层 |阅读模式
Features
• Wide operating range: 9 V to 80 V
• In-rush current limit for safe board insertion into
live power sources
• Programmable maximum power dissipation in the
external pass device
• Adjustable current limit
• Circuit breaker function for severe overcurrent
events
• Internal high side charge pump and gate driver for
external N-channel MOSFET
• Adjustable undervoltage lockout (UVLO) and
hysteresis
• Adjustable overvoltage lockout (OVLO) and
hysteresis
• Initial insertion timer allows ringing and transients
to subside after system connection
• Programmable fault timer avoids nuisance trips
• Active high open drain POWER GOOD output
• Available in latched fault and automatic restart
versions
• 10-Pin VSSOP packag
Applications
• Server backplane systems
• Base station power distribution systems
• Solid state circuit breaker
• 24-V and 48-V Industrial systems
Description
The ZCC5069 positive hot swap controller provides intelligent control of the power supply
connections during insertion and removal of circuit cards from a live system backplane or other hot
power sources.
The ZCC5069 provides  in-rush current control to limit system voltage droop and transients. The current  limit and power dissipation in the external series pass N-Channel MOSFET are  programmable, ensuring operation within the Safe Operating Area (SOA). The POWER GOOD output indicates when the output voltage is within 1.25 V of the input voltage. The input undervoltage and  overvoltage lockout levels and hysteresis are programmable, as well as the initial insertion delay  time  and  fault  detection  time.
The ZCC5069-1  latches  off  after a fault detection,
while the  ZCC5069-2 automatically restarts at a fixed duty cycle. ZCC5069 is available in a 10-pin VSSOP
package.
