pickit3 命令行烧写有bug?
3750|2
 楼主| zhaosr19 发表于 2012-6-24 22:40 | 显示全部楼层 |阅读模式
pickit3 命令行烧写有bug?
\Microchip\MPLAB IDE\Readmes\Readme for PK3CMD.txt
mplab ide安装目录下有pickit3命令行帮助文件,我按照这个帮助,把原先能够正常使用的pickit3,在命令行烧写成功后(好像是2次),然后用mplab ide,命令行烧写都不正常了
6月21日
命令行烧写正常
D:\Program Files\Microchip\MPLAB IDE\Programmer Utilities\PICkit3>PK3CMD -P16F72
3 -FF:\E\project\Engine\16f1823\ECU\ECU.hex -M
Connecting...
PICkit 3 detected
Connecting to PICkit 3...
Firmware Suite Version...... 01.27.04
Firmware type......................Midrange
PICkit 3 Connected.
Target Detected
Device ID Revision = 00000012
Programming Device ...
Programming/Verify complete
今天烧写就有问题了
Connecting...
PICkit 3 detected
PICkit 3 Connected.
Target Detected
Program Memory
Address: 0000000c Expected Value: 00002a6c Received Value: 00002a00
Programming failed
Failed to perform Program  !!!
下图是ide中使用pickit3时有问题的
Ryanhsiung 发表于 2012-6-25 08:07 | 显示全部楼层
线可能没接好!!
 楼主| zhaosr19 发表于 2012-6-25 08:54 | 显示全部楼层
应该不是这样的问题,我手上有5、6块板子,都有这样的问题
