回收租售维修二手致茂Chroma 62150H-600 大功率直流电源
430|0
szffr123 发表于 2025-11-3 09:57 | 显示全部楼层 |阅读模式
Chroma 62150H-600 High-Power DC Power Supply: A Reliable Power Foundation for High-Energy-Consumption Electronic Testing
In the R&D and production testing of fields such as electric vehicles, industrial motors, high-power server supplies, and renewable energy, test systems require continuous, stable, and clean high-power DC electricity. Chroma's 62150H-600 Programmable DC Power Supply is a high-performance power solution designed to meet these stringent demands. With its robust output capability, excellent output quality, and flexible programming control, it serves as a core instrument in the testing of high-energy-consumption electronic equipment.
Ensuring the long-term stable operation of such critical high-power equipment and the accuracy of its voltage and current output is crucial for test safety and data validity. The Shenzhen Bao'an Shajing Fangfengrui Instrument Equipment Business Department provides professional technical services and support for the maintenance of such system power supplies.
62150H-600: Balancing Power and Precision
The core value of this model lies in its ability to provide kilowatt-level high-power output while maintaining the precision, low ripple/noise, and fast response characteristics of a programmable power supply.
Core Performance and Technical Features:
  • Powerful Output Capability:
    • A single unit provides 15kW of high-power output (Model 62150H-600: Output Voltage 0-600V, Output Current 0-25A), capable of directly meeting the input test requirements for most high-power devices (e.g., onboard chargers, motor controllers, high-power servers).
    • Supports master-slave parallel operation, allowing power to be easily expanded to hundreds of kilowatts by connecting multiple units in parallel, offering a flexible solution for higher-power test applications (e.g., energy storage converter testing).
  • Excellent Output Quality and Stability:
    • Extremely low ripple and noise, ensuring a "clean" DC power supply for the device under test (DUT), preventing power supply noise from interfering with test results or affecting the DUT's normal operation.
    • High precision programming and readback, coupled with fast load transient response, effectively suppresses overshoot and sag in the output voltage.
  • Rich Operating Modes and Protection Functions:
    • In addition to Constant Voltage (CV) and Constant Current (CC) modes, it also supports Constant Power (CP) mode, facilitating specific test applications like battery simulation.
    • Provides comprehensive Over Voltage Protection (OVP), Over Current Protection (OCP), Over Temperature Protection (OTP), and Over Power Protection (OPP). Allows setting of voltage and current slew rates, effectively protecting sensitive DUTs.
  • Flexible Communication and Control Interfaces:
    • Standard communication interfaces include GPIB, LAN, and USB, enabling easy integration into automated test systems for remote programming and control, meeting the needs of production line automated testing.
Key Application Scenarios
  • Electric Vehicle Component Testing: Input performance and efficiency testing for On-Board Chargers (OBC), DC-DC Converters, and motor controllers.
  • Server and Data Center Power Supply Testing: Providing test conditions such as full load and surge tests for high-power server and switch power supplies.
  • Renewable Energy and Industrial Power Electronics: R&D verification and production testing for photovoltaic inverters and energy storage converters.
  • Battery Simulation: Simulating battery charge/discharge characteristics via external programming for Battery Management System (BMS) testing.
Ensuring Sustainable Operation of High-Power Systems
Under long-term high-load operation, the performance of key internal components like power devices and filter capacitors in high-power supplies will gradually degrade. This can lead to decreased output accuracy, increased ripple, or even failure and shutdown. Regular performance verification and preventive maintenance are key to ensuring test continuity and safety.
The Shenzhen Bao'an Shajing Fangfengrui Instrument Equipment Business Department provides critical support in this area:
  • Performance Verification and Calibration: Periodic metrology calibration of key indicators like output voltage, current, and ripple for the 62150H-600, ensuring the accuracy and traceability of its output values, thereby guaranteeing the credibility of test data.
  • Preventive Maintenance and Inspection: Deep cleaning of equipment, inspecting and tightening internal connections, assessing the status of wearable parts like fans and capacitors to prevent problems before they occur and reduce the risk of unexpected downtime.
  • Professional Fault Diagnosis and Repair: Provides board-level or component-level professional repair services for faults such as no output, abnormal output, or alarms, quickly restoring equipment functionality.
  • System Integration Consultation: Offers professional system setup and integration advice based on user's specific test needs (e.g., whether parallel operation for power expansion is needed, how to configure host computer software).
Conclusion
The Chroma 62150H-600 High-Power DC Power Supply, with its strong output capability and reliable performance, has become an indispensable "power heart" in the field of high-energy-consumption electronic equipment testing. Ensuring this "heart" beats strongly and persistently is the foundation for guaranteeing the efficient and reliable operation of the entire test system.
Partnering with a professional service provider like the Shenzhen Bao'an Shajing Fangfengrui Instrument Equipment Business Department means users can obtain full lifecycle management—from precise metrology and preventive maintenance to rapid repair—for their critical test platforms, maximizing the return on equipment investment and ensuring the smooth progress of testing tasks.
A company integrating electronic instrument sales, test solution provision, pre-sales services, instrument equipment repair, instrument rental, recycling, and calibration services.
Contact:
Mr. Deng: 135-1015-2816 (WeChat ID same as number)
Chroma 62150H-600 大功率直流电源:高能耗电子测试的可靠动力基石
在电动汽车、工业电机、大功率服务器电源及可再生能源等领域的研发与生产测试中,测试系统需要能够提供持续、稳定且纯净的大功率直流电。致茂电子(Chroma)的 62150H-600 可编程直流电源正是为满足此类严苛需求而设计的高性能电源解决方案,以其强大的输出能力、优异的输出品质和灵活的编程控制,成为高能耗电子设备测试领域的核心设备。
确保此类大功率关键设备长期稳定运行,并提供准确的电压电流输出,对于测试的安全性与数据的有效性至关重要。深圳市宝安区沙井方丰瑞仪器设备经营部 在此类系统电源的支持与维护方面,能够提供专业的技术服务保障。
62150H-600:动力与精度的平衡
该型号的核心价值在于其在提供千瓦级大功率输出的同时,保持了程控电源的精度、低纹波噪声和快速响应特性。
核心性能与技术特点:
  • 强大的功率输出能力:
    • 单机提供 15kW 的高功率输出(型号62150H-600,输出电压0-600V,输出电流0-25A),能够直接满足多数大功率设备(如车载充电机、电机控制器、大功率服务器)的输入测试需求。
    • 支持主从并联功能,通过多台并联可轻松将功率扩展至数百千瓦,为更高功率的测试应用(如储能变流器测试)提供了灵活的解决方案。
  • 优异的输出质量与稳定性:
    • 极低的低纹波和噪声,确保为被测设备提供“纯净”的直流电源,避免电源噪声干扰测试结果或影响被测设备的正常工作。
    • 高精度编程与回读,同时具备快速的负载瞬态响应能力,能有效抑制输出电压的过冲和跌落。
  • 丰富的操作模式与保护功能:
    • 除了恒压(CV)和恒流(CC)模式外,还支持恒功率(CP)模式,方便电池模拟等特定测试应用。
    • 提供完备的过电压、过电流、过温度和过功率保护,并能设置电压和电流的上升/下降斜率(Slew Rate),有效保护敏感的被测设备。
  • 灵活的通信与控制接口:
    • 标配GPIB、LAN、USB等通信接口,可轻松集成到自动化测试系统中,实现远程编程与控制,满足生产线自动化测试的需求。
关键应用场景
  • 电动汽车部件测试:用于车载充电机(OBC)、直流-直流转换器(DC-DC Converter)、电机控制器的输入性能与效率测试。
  • 服务器与数据中心电源测试:为大功率服务器电源、交换机电源提供满载、浪涌等测试条件。
  • 可再生能源与工业电力电子:用于光伏逆变器、储能变流器的前期研发验证与生产测试。
  • 电池模拟:通过外部编程,模拟电池的充放电特性,用于BMS(电池管理系统)的测试。
大功率系统的可持续运行保障
大功率电源在长期高负荷运行下,其内部功率器件、滤波电容等关键元件的性能会逐渐衰减,可能导致输出精度下降、纹波增大甚至故障停机。定期的性能验证与预防性维护是保障测试连续性与安全性的关键。
深圳市宝安区沙井方丰瑞仪器设备经营部 在此领域能够为用户提供关键支持:
  • 性能验证与校准:定期对62150H-600的输出电压、电流、纹波等关键指标进行计量校准,确保其输出值的准确性与可追溯性,保障测试数据的可信度。
  • 预防性维护与检修:对设备进行深度清洁、检查并紧固内部连接,评估风扇、电容等易损件状态,防范于未然,降低意外停机风险。
  • 专业故障诊断与维修:针对无输出、输出异常、报警等故障,提供板卡级或元件级的专业维修服务,快速恢复设备功能。
  • 系统集成咨询:根据用户的测试需求(如是否需要并联扩容、如何配置上位机软件等),提供专业的系统搭建与集成建议。
结论
Chroma 62150H-600 大功率直流电源以其强大的输出能力和可靠的性能,成为了高能耗电子设备测试领域中不可或缺的“动力心脏”。确保这颗“心脏”强劲且持久地跳动,是保障整个测试系统高效、可靠运行的基础。
与 深圳市宝安区沙井方丰瑞仪器设备经营部 这样的专业服务伙伴合作,意味着用户可以为自己的关键测试平台获得从精准计量、预防性维护到快速维修的全生命周期管理,最大化设备投资回报,确保测试任务顺利进行。
