[应用相关] 基于N32L40X修改的江科大4线IIC接口OLED驱动代码
2848|0
八层楼 发表于 2025-11-6 19:39 | 显示全部楼层 |阅读模式
1 软件iic
c文件
#include "iic_basen32lib.h"
* @brief  Inserts a delay time.
* @param count specifies the delay time length.
void delay_us(uint32_t count)
    count=(count*4);
    for (; count > 0; count--)
        __nop();
        __nop();
        __nop();
        __nop();
        __nop();
        __nop();
        __nop();
        __nop();
        __nop();
void delay_ms(uint32_t count)
        delay_us(1006);
  * @brief SDA线输入模式配置
  * @param bus IIC总线控制器
  * @retval None
static void SDA_Input_Mode(s_iic_bus_t* bus)
    GPIO_InitType GPIO_InitStructure ;
    GPIO_InitStruct(&GPIO_InitStructure);
    GPIO_InitStructure.Pin = bus->IIC_SDA_PIN;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Input;
    GPIO_InitStructure.GPIO_Pull = GPIO_No_Pull;
    GPIO_InitPeripheral(bus->IIC_SDA_GPIO, &GPIO_InitStructure);
  * @brief SDA线输出模式配置
  * @retval None
static void SDA_Output_Mode(s_iic_bus_t *bus)
    GPIO_InitType GPIO_InitStructure;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  * @brief SDA线输出一个位
  * @param bus IIC总线控制器 val 输出的数据 1/0
  * @retval None
static void SDA_Output(s_iic_bus_t *bus, uint8_t val)
                if(val)GPIO_SetBits(bus->IIC_SDA_GPIO,bus->IIC_SDA_PIN);
                else GPIO_ResetBits(bus->IIC_SDA_GPIO,bus->IIC_SDA_PIN);
  * @brief SCL线输出一个位
  * @retval None
static void SCL_Output(s_iic_bus_t *bus, uint8_t val)
          if(val)GPIO_SetBits(bus->IIC_SCL_GPIO,bus->IIC_SCL_PIN);
                else GPIO_ResetBits(bus->IIC_SCL_GPIO,bus->IIC_SCL_PIN);
  * @brief SDA输入一位
        * @return 读到的一位数据
  * @retval GPIO读入一位
uint8_t SDA_Input(s_iic_bus_t *bus)
        return GPIO_ReadInputDataBit(bus->IIC_SDA_GPIO,bus->IIC_SDA_PIN);
// _____
// SDA: |_____
// _______
// SCL:   |___
  * @brief IIC起始信号
  * @retval None
void IICStart(s_iic_bus_t *bus)
        SDA_Output_Mode(bus);
        SDA_Output(bus,1);
        SCL_Output(bus,1);
        delay_us(4);
        SDA_Output(bus,0);
        delay_us(4);
        SCL_Output(bus,0);
//            _____
// SDA: _____|
//          _______
// SCL: ___|
  * @brief IIC结束信号
  * @retval None
void IICStop(s_iic_bus_t *bus)
        SCL_Output(bus,0);
        SDA_Output(bus,0);
        delay_us(4);
        SCL_Output(bus,1);
        delay_us(4);
        SDA_Output(bus,1);
        delay_us(4);
// 应答___        非应答      __________
// SDA:   |_______     SDA:
//         _____                  _____
// SCL:___|     |      SCL:   ___|     |
  * @brief IIC主机等待从机应答
  * @retval None
uint8_t IICWaitAck(s_iic_bus_t *bus)
        uint8_t ucErrTime=0;
        SDA_Input_Mode(bus);
        SDA_Output(bus,1);
        delay_us(1);
        SCL_Output(bus,1);
        delay_us(1);
        while((SDA_Input(bus)==1))//应答超时
                        ucErrTime++;
                if(ucErrTime >=250)
                        IICStop(bus);
                        return 1;
                SCL_Output(bus,0);
                return 0;
  * @brief IIC发送应答信号(主机)
  * @retval None
void IICSendAck(s_iic_bus_t *bus)
        SCL_Output(bus,0);
        SDA_Output(bus,0);
        delay_us(2);
        SCL_Output(bus,1);
        delay_us(2);
        SCL_Output(bus,0);
  * @brief IIC发送非应答信号(主机)
  * @retval None
void IICSendNotAck(s_iic_bus_t *bus)
        SCL_Output(bus,0);
        SDA_Output(bus,1);
        delay_us(2);
        SCL_Output(bus,1);
        delay_us(2);
        SCL_Output(bus,0);
  * @brief IIC发送一个字节
  * @param byte 需要发送的字节
  * @retval None
void IICSendByte(s_iic_bus_t *bus,uint8_t cSendByte)
  uint8_t  i = 0;
        SCL_Output(bus,0);
        for(i=0;i<8;i++)
                if((cSendByte&0x80)>>7)SDA_Output(bus,1);
                else SDA_Output(bus,0);
                cSendByte <<=1;
                delay_us(2);
                SCL_Output(bus,1);
                delay_us(2);
                SCL_Output(bus,0);
                delay_us(2);
  * @brief IIC接收一个字节
  * @param None 0 nack 1 ack
  * @retval 接收到的字节
uint8_t IICReceiveByte(s_iic_bus_t *bus, uint8_t ack)
                uint8_t i = 0;
    uint8_t cReceiveByte = 0;
          for(i=0;i<8;i++)
                        SCL_Output(bus,0);
                        delay_us(2);
                        SCL_Output(bus,1);
                        cReceiveByte <<=1;
                        if(SDA_Input(bus))
                                cReceiveByte++;
                        delay_us(2);
                if(!ack ) IICSendNotAck(bus);
                else IICSendAck(bus);
                return cReceiveByte;
void IICInit(s_iic_bus_t *bus)
         GPIO_InitType GPIO_InitStructure ;   /*初始化GPIO结构体*/
         GPIO_InitStructure.Pin            = bus->IIC_SCL_PIN ;
         GPIO_InitStructure.GPIO_Current   = GPIO_DC_4mA;
         GPIO_InitStructure.GPIO_Slew_Rate = GPIO_Slew_Rate_High;//以高速50M速率为例 翻转电平仅需20ns
         GPIO_InitPeripheral(bus->IIC_SCL_GPIO, &GPIO_InitStructure);
         GPIO_InitStructure.Pin            = bus->IIC_SDA_PIN ;
         GPIO_SetBits(bus->IIC_SDA_GPIO,bus->IIC_SDA_PIN);/*拉高总线*/
头文件
#ifndef __IIC_SOFT_H
#define __IIC_SOFT_H
#include "n32l40x.h"
typedef struct
        GPIO_Module* IIC_SDA_GPIO;
        GPIO_Module* IIC_SCL_GPIO;
        uint16_t IIC_SDA_PIN;
        uint16_t IIC_SCL_PIN;
}s_iic_bus_t;/*IIC总线控制器*/
* Function Name  : delay_us
* Description    : 延时us
* Input          : count 延时nus
*                  None
* Return         : None
void delay_us(uint32_t count);
* Function Name  : delay_ms
* Description    : 延时ms
* Input          : count 延时nms
*                  None
* Return         : None
void delay_ms(uint32_t count);
* Function Name  : IICStart
* Description    : 开始信号
* Input          : bus 对应IIC总线控制器
*                  None
* Return         : None
void IICStart(s_iic_bus_t *bus);
* Function Name  : IICStop
* Description    : 停止信号
*                  None
* Return         : None
void IICStop(s_iic_bus_t *bus);
* Function Name  : IICWaitAck
* Description    : 主机等待应答
*                  None
* Return         : None
uint8_t IICWaitAck(s_iic_bus_t *bus);
* Function Name  : IICSendAck
* Description    : 主机发送应答
*                  None
* Return         : None
void IICSendAck(s_iic_bus_t *bus);
* Function Name  : IICSendNotAck
* Description    : 主机发送非应答
*                  None
* Return         : None
void IICSendNotAck(s_iic_bus_t *bus);
* Function Name  : IICSendByte
* Description    : 发送一个字节
*                  None
* Return         : None
void IICSendByte(s_iic_bus_t *bus, uint8_t cSendByte);
* Function Name  : IICReceiveByte
* Description    : 接收一个字节
*                  None
* Return         : None
uint8_t IICReceiveByte(s_iic_bus_t *bus, uint8_t ack);
* Function Name  : IICInit
* Description    : IIC总线初始化
*                  None
* Return         : None
void IICInit(s_iic_bus_t *bus);
#endif
2 OLED驱动
#include "OLED_Font.h"
#include "OLED.h"
s_iic_bus_t oled_bus =
        .IIC_SDA_GPIO = GPIOA,
        .IIC_SCL_GPIO = GPIOA,
        .IIC_SDA_PIN  = GPIO_PIN_11,
        .IIC_SCL_PIN  = GPIO_PIN_12,
/*引脚初始化*/
void OLED_I2C_Init(void)
    IICInit(&oled_bus);
  * @brief  OLED写命令
  * @param  Command 要写入的命令
  * @retval 无
void OLED_WriteCommand(uint8_t Command)
        IICStart(&oled_bus);
        IICSendByte(&oled_bus,0x78);                //从机地址
        IICWaitAck(&oled_bus);
        IICSendByte(&oled_bus,0x00);                //写命令
        IICSendByte(&oled_bus,Command);
        IICStop(&oled_bus);
  * @brief  OLED写数据
  * @param  Data 要写入的数据
  * @retval 无
void OLED_WriteData(uint8_t Data)
        IICSendByte(&oled_bus,0x40);                //写数据
        IICSendByte(&oled_bus,Data);                //写命令
        IICStop(&oled_bus);
  * @brief  OLED设置光标位置
  * @param  Y 以左上角为原点,向下方向的坐标,范围:0~7
  * @param  X 以左上角为原点,向右方向的坐标,范围:0~127
  * @retval 无
void OLED_SetCursor(uint8_t Y, uint8_t X)
        OLED_WriteCommand(0xB0 | Y);                                        //设置Y位置
        OLED_WriteCommand(0x10 | ((X & 0xF0) >> 4));        //设置X位置高4位
        OLED_WriteCommand(0x00 | (X & 0x0F));                        //设置X位置低4位
  * @brief  OLED清屏
  * @param  无
  * @retval 无
void OLED_Clear(void)
        uint8_t i, j;
        for (j = 0; j < 8; j++)
                OLED_SetCursor(j, 0);
                for(i = 0; i < 128; i++)
                        OLED_WriteData(0x00);
  * @brief  OLED显示一个字符
  * @param  Line 行位置,范围:1~4
  * @param  Column 列位置,范围:1~16
  * @param  Char 要显示的一个字符,范围:ASCII可见字符
  * @retval 无
void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char)
        uint8_t i;
        OLED_SetCursor((Line - 1) * 2, (Column - 1) * 8);                //设置光标位置在上半部分
        for (i = 0; i < 8; i++)
                OLED_WriteData(OLED_F8x16[Char - ' ']);                        //显示上半部分内容
        OLED_SetCursor((Line - 1) * 2 + 1, (Column - 1) * 8);        //设置光标位置在下半部分
                OLED_WriteData(OLED_F8x16[Char - ' '][i + 8]);                //显示下半部分内容
  * @brief  OLED显示字符串
  * @param  Line 起始行位置,范围:1~4
  * @param  Column 起始列位置,范围:1~16
  * @param  String 要显示的字符串,范围:ASCII可见字符
  * @retval 无
void OLED_ShowString(uint8_t Line, uint8_t Column, char *String)
        uint8_t i;
        for (i = 0; String != '\0'; i++)
                OLED_ShowChar(Line, Column + i, String);
  * @brief  OLED次方函数
  * @retval 返回值等于X的Y次方
uint32_t OLED_Pow(uint32_t X, uint32_t Y)
        uint32_t Result = 1;
        while (Y--)
                Result *= X;
        return Result;
  * @brief  OLED显示数字(十进制,正数)
  * @param  Number 要显示的数字,范围:0~4294967295
  * @param  Length 要显示数字的长度,范围:1~10
  * @retval 无
void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
        uint8_t i;
        for (i = 0; i < Length; i++)
                OLED_ShowChar(Line, Column + i, Number / OLED_Pow(10, Length - i - 1) % 10 + '0');
  * @brief  OLED显示数字(十进制,带符号数)
  * @param  Number 要显示的数字,范围:-2147483648~2147483647
  * @retval 无
void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length)
        uint8_t i;
        uint32_t Number1;
        if (Number >= 0)
                OLED_ShowChar(Line, Column, '+');
                Number1 = Number;
        else
                OLED_ShowChar(Line, Column, '-');
                Number1 = -Number;
                OLED_ShowChar(Line, Column + i + 1, Number1 / OLED_Pow(10, Length - i - 1) % 10 + '0');
  * @brief  OLED显示数字(十六进制,正数)
  * @param  Number 要显示的数字,范围:0~0xFFFFFFFF
  * @param  Length 要显示数字的长度,范围:1~8
  * @retval 无
void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
        uint8_t i, SingleNumber;
                SingleNumber = Number / OLED_Pow(16, Length - i - 1) % 16;
                if (SingleNumber < 10)
                        OLED_ShowChar(Line, Column + i, SingleNumber + '0');
                else
                        OLED_ShowChar(Line, Column + i, SingleNumber - 10 + 'A');
  * @brief  OLED显示数字(二进制,正数)
  * @param  Number 要显示的数字,范围:0~1111 1111 1111 1111
  * @param  Length 要显示数字的长度,范围:1~16
  * @retval 无
void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length)
        uint8_t i;
                OLED_ShowChar(Line, Column + i, Number / OLED_Pow(2, Length - i - 1) % 2 + '0');
  * @brief  OLED初始化
  * @param  无
  * @retval 无
void OLED_Init(void)
        uint32_t i, j;
        for (i = 0; i < 1000; i++)                        //上电延时
                for (j = 0; j < 1000; j++);
        OLED_I2C_Init();                        //端口初始化
        OLED_WriteCommand(0xAE);        //关闭显示
        OLED_WriteCommand(0xD5);        //设置显示时钟分频比/振荡器频率
        OLED_WriteCommand(0x80);
        OLED_WriteCommand(0xA8);        //设置多路复用率
        OLED_WriteCommand(0x3F);
        OLED_WriteCommand(0xD3);        //设置显示偏移
        OLED_WriteCommand(0x00);
        OLED_WriteCommand(0x40);        //设置显示开始行
        OLED_WriteCommand(0xA1);        //设置左右方向,0xA1正常 0xA0左右反置
        OLED_WriteCommand(0xC8);        //设置上下方向,0xC8正常 0xC0上下反置
        OLED_WriteCommand(0xDA);        //设置COM引脚硬件配置
        OLED_WriteCommand(0x12);
        OLED_WriteCommand(0x81);        //设置对比度控制
        OLED_WriteCommand(0xCF);
        OLED_WriteCommand(0xD9);        //设置预充电周期
        OLED_WriteCommand(0xF1);
        OLED_WriteCommand(0xDB);        //设置VCOMH取消选择级别
        OLED_WriteCommand(0x30);
        OLED_WriteCommand(0xA4);        //设置整个显示打开/关闭
        OLED_WriteCommand(0xA6);        //设置正常/倒转显示
        OLED_WriteCommand(0x8D);        //设置充电泵
        OLED_WriteCommand(0x14);
        OLED_WriteCommand(0xAF);        //开启显示
        OLED_Clear();                                //OLED清屏
#ifndef __OLED_H
#define __OLED_H
void OLED_Init(void);
void OLED_Clear(void);
void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char);
void OLED_ShowString(uint8_t Line, uint8_t Column, char *String);
void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length);
void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
#endif
字库
#ifndef __OLED_FONT_H
#define __OLED_FONT_H
/*OLED字模库,宽8像素,高16像素*/
const uint8_t OLED_F8x16[][16]=
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//  0
        0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00,//! 1
        0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" 2
        0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,
        0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,//# 3
        0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,
        0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00,//$ 4
        0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,
        0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00,//% 5
        0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,
        0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10,//& 6
        0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//' 7
        0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,
        0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00,//( 8
        0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,
        0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00,//) 9
        0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,
        0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,//* 10
        0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,
        0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,//+ 11
        0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,//, 12
        0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,//- 13
        0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//. 14
        0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,
        0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,/// 15
        0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
        0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0 16
        0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1 17
        0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,
        0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2 18
        0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,
        0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3 19
        0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,
        0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4 20
        0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,
        0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5 21
        0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,
        0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6 22
        0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,
        0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7 23
        0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,
        0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8 24
        0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9 25
        0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,
        0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//: 26
        0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
        0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,//; 27
        0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,
        0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,//< 28
        0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,
        0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//= 29
        0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,
        0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,//> 30
        0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,
        0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00,//? 31
        0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,
        0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00,//@ 32
        0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,
        0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//A 33
        0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,
        0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,//B 34
        0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,
        0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,//C 35
        0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,
        0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//D 36
        0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,
        0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,//E 37
        0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00,//F 38
        0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,
        0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00,//G 39
        0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,
        0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//H 40
        0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//I 41
        0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,
        0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,//J 42
        0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,
        0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00,//K 43
        0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,
        0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00,//L 44
        0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,
        0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,//M 45
        0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,
        0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//N 46
        0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,
        0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,//O 47
        0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,
        0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00,//P 48
        0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,//Q 49
        0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,
        0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//R 50
        0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,
        0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//S 51
        0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,
        0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//T 52
        0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//U 53
        0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,
        0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//V 54
        0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,
        0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00,//W 55
        0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,
        0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20,//X 56
        0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,
        0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//Y 57
        0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,
        0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00,//Z 58
        0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,
        0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,//[ 59
        0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,//\ 60
        0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,
        0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,//] 61
        0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//^ 62
        0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,//_ 63
        0x00,0x02,0x02,0x04,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//` 64
        0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,
        0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,//a 65
        0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,
        0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,//b 66
        0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,
        0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,//c 67
        0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,
        0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,//d 68
        0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,//e 69
        0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//f 70
        0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,
        0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,//g 71
        0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,
        0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//h 72
        0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//i 73
        0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,
        0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,//j 74
        0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,
        0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,//k 75
        0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,
        0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//l 76
        0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
        0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,//m 77
        0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,
        0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//n 78
        0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//o 79
        0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,
        0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,//p 80
        0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,
        0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,//q 81
        0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,
        0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,//r 82
        0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,//s 83
        0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,
        0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,//t 84
        0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,
        0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,//u 85
        0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,
        0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,//v 86
        0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,
        0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,//w 87
        0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,
        0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,//x 88
        0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,//y 89
        0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
        0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,//z 90
        0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,
        0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40,//{ 91
        0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,//| 92
        0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,
        0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,//} 93
        0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//~ 94
#endif
3 逻辑分析仪抓取波形
原驱动来自江科大教程,在这里只做对N32L40X的适配工作。仅供参考。
版权声明:本文为CSDN博主「NEWEVA__zzera22」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/NEWEVA__zzera22/article/details/145055676
