[测量] 出售租赁维修二手安捷伦34970A数据采集/开关单元
323|0
szffr123 发表于 2025-11-18 11:00 | 显示全部楼层 |阅读模式
Agilent 34970A Data Acquisition/Switch Unit: A Reliable Foundation for Automated Testing
Product Overview
The Agilent 34970A Data Acquisition/Switch Unit serves as a classic modular testing platform that excels in applications requiring synchronous and precise measurement of multiple signal types, including electronic device development, industrial process monitoring, and environmental testing. Renowned for its flexibility, measurement accuracy, and stability, it has become a cornerstone in building automated test systems.
To ensure the long-term, stable operation of such critical data acquisition platforms, professional support and maintenance are essential. The Shenzhen Bao'an Shajing Fangfengrui Instrument Equipment Business Department provides comprehensive technical services throughout the instrument's lifecycle, ensuring optimal performance and reliability.
34970A: The Fusion of Flexibility and Precision
Core Features and Technical Specifications:
  • Versatile and High-Precision Measurement Core
    • Built-in 6.5-digit Digital Multimeter (DMM) for direct measurement of:
      • DC/AC voltage and current
      • 2-wire/4-wire resistance
      • Frequency and period
      • Temperature (via integrated thermocouples or RTDs)
    • High accuracy and low noise characteristics enable reliable performance across a wide range of tasks, from routine monitoring to precision validation.
  • Highly Modular and Flexible Design
    • Features 3 mainframe slots for seamless integration with Agilent's extensive range of switching and control modules.
    • Supports various signal relay types, including general-purpose relays, multiplexers, matrices, and digital I/O, allowing users to build customized measurement systems tailored to specific needs.
  • Extensive Data Logging and Connectivity
    • Equipped with up to 2 MB of non-volatile memory for long-term, unattended data logging.
    • Standard GPIB and RS-232 interfaces, with optional LAN and USB modules, enabling flexible remote control and data retrieval.
  • User-Friendly Operation and Software Support
    • Intuitive front-panel vacuum fluorescent display and navigation keys for easy local operation.
    • Fully compatible with software such as Keysight BenchVue, simplifying instrument control, data visualization, and analysis.
Typical Application Scenarios
  • Multi-Channel Temperature Monitoring: Synchronously records temperature data from hundreds of thermocouples or RTDs in environmental test chambers, battery testing, or industrial processes.
  • Component and Product Characterization Testing: Automatically scans and measures voltage, current, and resistance parameters of multiple units under test on production lines.
  • System Function Verification: Uses digital I/O modules to send control signals to the device under test while monitoring its voltage response.
  • Long-Term Reliability Monitoring: Conducts 24/7 uninterrupted monitoring of voltage, current, and temperature for critical equipment such as power supplies and server racks.
Professional Maintenance for Sustained System Performance
As a complex system integrating precision measurement and mechanical switching, the performance of the 34970A and its switch modules may degrade over time due to environmental factors and usage. Regular evaluation and calibration of relay lifespan, channel on-resistance, and measurement accuracy are critical to maintaining system integrity.
The Shenzhen Bao'an Shajing Fangfengrui Instrument Equipment Business Department offers the following key services:
  • System Configuration Consulting: Provides expert recommendations for optimizing 34970A mainframe and switch module configurations based on signal types, channel requirements, and budget constraints.
  • Regular Metrology and Calibration: Ensures the accuracy of the mainframe and all measurement modules complies with specifications, guaranteeing reliable and traceable data acquisition.
  • Comprehensive Diagnostics and Maintenance: Diagnoses and repairs issues such as relay failures, channel abnormalities, or measurement inaccuracies to restore system functionality and extend service life.
  • Legacy System Upgrades and Optimization: Offers performance evaluations and upgrade solutions (e.g., adding USB or LAN connectivity) to ensure aging 34970A systems meet evolving testing demands.
Conclusion
The Agilent 34970A Data Acquisition Unit stands as a benchmark in automated testing and data logging, balancing flexibility, precision, and reliability in a classic design.
Ensuring the durability of this foundational tool requires professional maintenance and support. By partnering with the Shenzhen Bao'an Shajing Fangfengrui Instrument Equipment Business Department, users gain end-to-end technical support—from initial system selection and mid-life operation to后期 upgrades—maximizing return on investment and ensuring the integrity of every data point.
A company integrating electronic instrument sales, test solutions, pre-sales services, instrument repair, equipment rental, recycling, and calibration services.
安捷伦34970A数据采集/开关单元:自动化测试的可靠基石
在电子设备研发、工业过程监控及环境试验验证等领域,经常需要对多路不同类型的信号进行同步、精确的测量与记录。安捷伦(Agilent,现为是德科技Keysight)34970A数据采集/开关单元作为一款经典的模块化测试平台,以其出色的灵活性、测量精度和稳定性,成为构建自动化测试系统的核心设备之一。
为确保此类承担关键数据采集任务的平台长期稳定运行,专业的支持与维护服务不可或缺。深圳市宝安区沙井方丰瑞仪器设备经营部在此类仪器的全生命周期管理中,能够提供专业的技术服务保障。
34970A:灵活性与精度的融合
核心功能与技术特点:
  • 多功能、高精度的测量核心
    • 内置的 6.5 位数字万用表(DMM) 支持直接测量直流/交流电压、直流/交流电流、2线/4线电阻、频率、周期,并通过内置热电偶或RTD直接测量温度。
    • 其高精度和低噪声特性,使其能够胜任从常规监控到精密验证的多层次测量任务。
  • 高度模块化的灵活性
    • 主机提供 3 个插槽,可自由搭配安捷伦丰富的开关与控制模块。用户可根据需求配置不同类型的信号继电器(如通用继电器、多路复用器、矩阵、数字I/O等),轻松构建定制化的测量系统。
  • 广泛的数据记录与连接能力
    • 内置 高达2MB 的非易失性存储器,便于进行长时间、无人值守的数据记录。
    • 标配 GPIB 和 RS-232 接口,并可轻松添加 LAN 和 USB 模块,实现灵活的远程控制和数据读取。
  • 直观的操作与强大的软件支持
    • 前面板真空荧光显示屏和导航键便于本地操作。同时,其与 Keysight BenchVue 等软件的完美兼容,使得仪器控制、数据可视化和分析变得异常简便。
典型应用场景
  • 多通道温度监测:在环境试验箱、电池测试或工业过程中,同步记录多达上百个热电偶或热电阻的温度数据。
  • 元器件与产品特性测试:在生产线上,自动扫描测量多个被测单元的电压、电流和电阻参数。
  • 系统功能验证:通过数字 I/O 模块,向待测系统发送控制信号,并同时监测其响应电压。
  • 长期可靠性监控:对电源、服务器机柜等设备进行 7x24 小时不间断的电压、电流和温度监控。
专业系统的持续运行依赖专业维护
作为一个集成了精密测量与机械开关的复杂系统,34970A 及其开关模块的性能会随着使用时间和环境而变化。继电器的寿命、测量通道的导通电阻、以及仪器的测量精度都需要定期评估与校准。
深圳市宝安区沙井方丰瑞仪器设备经营部 在此领域能够为用户提供关键支持:
  • 系统配置咨询:根据用户的信号类型、通道数量和预算,提供 34970A 主机与开关模块的最佳配置方案建议。
  • 定期计量与校准:确保主机和所有测量模块的精度符合规范,保障数据采集的准确性和可追溯性。
  • 全面诊断与维护:对因继电器寿命耗尽、通道故障或测量异常等问题进行专业诊断与维修,有效恢复系统功能,延长设备使用寿命。
  • 旧系统升级与优化:为使用多年的 34970A 系统提供性能评估与升级建议(如增加USB或LAN connectivity),确保其能够持续满足新的测试需求。
结语
安捷伦34970A数据采集单元以其经典的设计,在灵活性、精度和可靠性之间取得了卓越的平衡,成为了自动化测试与数据记录领域的基石型产品。
确保这一基石的稳固,需要专业的维护作为后盾。与 深圳市宝安区沙井方丰瑞仪器设备经营部 这样的专业服务商合作,意味着用户可以为自己的关键测试系统获得从前期选型、中期运维到后期升级的全方位技术保障,最大化投资回报,确保数据始终可信。
