[PSOC™] 【英飞凌 CY8CKIT-062S2-AI评测】06MQTT上报雷达存在检测
419|1
EPTmachine 发表于 2025-11-18 18:59 | 显示全部楼层 |阅读模式
【英飞凌 CY8CKIT-062S2-AI评测】03雷达传感器存在检测
https://bbs.21ic.com/icview-3496036-1-1.html
(出处: 21ic电子技术开**坛)
【英飞凌 CY8CKIT-062S2-AI评测】05MQTT实现LED、按键的监控
https://bbs.21ic.com/icview-3496315-1-1.html
(出处: 21ic电子技术开**坛)
上述帖子中对雷达存在检测以及MQTT上报开发板外设的功能进行说明,在此基础上,将雷达的存在检测结果使用MQTT协议上报,将雷达设备信息接入物联网。
1、创建雷达存在主题
雷达存在结果的上报需要使用MQTT的发布功能,将结果发布到MQTT网络中,供订阅方获取数据。在mqtt_client_config.h中添加雷达存在结果相关的主题。
#define MQTT_PUB_RADAR_PRESENCE_TOPIC     "radar_presence"
对应的添加雷达存在检测的枚举变量以及信息结构体,以及在publisher_task函数中添加对于雷达检测事件的发布处理。
typedef enum
    PUBLISHER_INIT,
    PUBLISHER_DEINIT,
    PUBLISH_MQTT_MSG,
    PUBLISH_MQTT_RADAR_MSG
} publisher_cmd_t;
/* Structure to store publish message information. */
cy_mqtt_publish_info_t publish_radar_info =
    .qos = (cy_mqtt_qos_t) MQTT_MESSAGES_QOS,
    .topic = MQTT_PUB_RADAR_PRESENCE_TOPIC,
    .topic_len = (sizeof(MQTT_PUB_RADAR_PRESENCE_TOPIC) - 1),
    .retain = false,
    .dup = false
void publisher_task(void *pvParameters)
    while (true)
        /* Wait for commands from other tasks and callbacks. */
        if (pdTRUE == xQueueReceive(publisher_task_q, &publisher_q_data, portMAX_DELAY))
            switch(publisher_q_data.cmd)
                case PUBLISH_MQTT_RADAR_MSG:
                    /* Publish the data received over the message queue. */
                    publish_radar_info.payload = publisher_q_data.data;
                    publish_radar_info.payload_len = strlen(publish_radar_info.payload);
                    result = cy_mqtt_publish(mqtt_connection, &publish_radar_info);
                    if (result != CY_RSLT_SUCCESS)
                        printf("  Publisher: MQTT Publish failed with error 0x%0X.\n\n", (int)result);
                        /* Communicate the publish failure with the the MQTT
                            * client task.
                        mqtt_task_cmd = HANDLE_MQTT_PUBLISH_FAILURE;
                        xQueueSend(mqtt_task_q, &mqtt_task_cmd, portMAX_DELAY);
                    print_heap_usage("publisher_task: After publishing an MQTT message");
                    break;
2、雷达检测处理
在雷达存在检测的回调函数中,根据不同的存在检测结果,生成不同的信息,并通过队列发送到发布任务中处理,用于雷达存在检测结果的上报。
void presence_detection_cb(xensiv_radar_presence_handle_t handle,
                           const xensiv_radar_presence_event_t* event,
                           void *data)
    (void)handle;
    (void)data;
    publisher_data_t publisher_q_data;
    /* Assign the publish command to be sent to the publisher task. */
    publisher_q_data.cmd = PUBLISH_MQTT_RADAR_MSG;
    if (!ce_app_state.verbose)
        switch (event->state)
            case XENSIV_RADAR_PRESENCE_STATE_MACRO_PRESENCE:
                memset(radar_publish_info,0,24);
                printf("macro presence %" PRIi32 " %" PRIi32 "\n",
                event->range_bin,
                event->timestamp);
                sprintf(radar_publish_info,"macro presence %" PRIi32 " %" PRIi32 "\n",
                event->range_bin,
                event->timestamp);
                publisher_q_data.data=radar_publish_info;
                xQueueSend(publisher_task_q, &publisher_q_data,0);
                break;
            case XENSIV_RADAR_PRESENCE_STATE_ABSENCE:
                printf("absence %" PRIu32 "\n", event->timestamp);
                sprintf(radar_publish_info,"absence %" PRIu32 "\n", event->timestamp);
                break;
            default:
                printf("[MSG] ERROR: Unknown reported state in event handling\n");
                break;
    /* save the last reported event state */
    ce_app_state.last_reported_event = *event;
程序烧录到开发板后,可以看到雷达存在检测的输出以及通过MQTT上报的情况。
总结
通过PSoC6 AI Evaluation Kit的评测,体验英飞凌的ModusToolbox在工程创建和组件管理上的便利功能,加上Git版本管理支持下的"Train Model"代码管理,可以方便实现复杂工程的搭建和移植。DEEPCRAFT Stuido的Ready AI Model让AI应用快速部署成为可能,降低通用AI场景中程序的开发难度。
upload 附件:MQTT_LED.zip
小夏天的大西瓜 发表于 2025-11-25 22:03 | 显示全部楼层
MQTT上报雷达存在检测
