IPE6.25 ICD5 CONNECT点击后出现如下错误:
MPLABComm USB Version: 3.48
MPLABComm Serial Access Version: N/A
Transmission on endpoint 2 failed (err = -109)
You have set the program speed to Normal. The circuit on your board may require you to slow the speed down. Please change the setting in the tool properties to low and try the operation again.
Failed to get Device ID. Please make sure the target device is attached and try the operation ag
请问要怎样解决?
