[产品供应] 三星电池授权代理商富利佳电子
1883|0
 楼主| andyzhugf 发表于 2012-6-26 09:39 | 显示全部楼层 |阅读模式
Model Nominal
Capacity
(mAh) Nominal
Voltage (V) Charge
Method(V) Max.
Charge
Current(C) Discharge
Voltage(V) Discharge
Current(C) Dimension(mm) Max
Weight(g) Remark
Thickness Width Length
ICR18650-30A 3000 3.78 4.35 0.5 2.75 0.2 18 - 65 48 Safety
Functional
Layer
ICR18650-28A 2800 3.75 4.3 0.8 2.75 0.2 18 - 65 48
ICR18650-26F 2600 3.7 4.2 0.5 2.75 0.2 18 - 65 45 NCM/LCO
ICR18650-26D 2600 3.7 4.2 0.5 2.75 0.2 18 - 65 46
ICR18650-24F 2400 3.7 4.2 0.5 2.75 0.2 18 - 65 45 NCM
ICR18650-24E 2400 3.7 4.2 0.5 2.75 0.2 18 - 65 46.5
ICR18650-22F 2250 3.6 4.2 0.5 2.75 0.2 18 - 65 44.2 NCM
ICR18650-20F 2000 3.65 4.2 0.5 2.75 0.2 18 - 65 43.6 NCM/LMO
INR18650-15R 1500/25A 3.6 4.2 0.5 2.5 0.2 18 - 65 45 NCA
INR18650-15Q 1500/18A 3.6 4.2 0.5 2.5 0.2 18 - 65 45 NCA
INR18650-13R 1300/25A 3.6 4.2 0.5 2.5 0.2 18 - 65 45 NCA
INR18650-13Q 1300/18A 3.6 4.2 0.5 2.5 0.2 18 - 65 43.5 NCA
INR18650-13P 1300/10A 3.6 4.2 0.5 2.5 0.2 18 - 65 43.5 NCA
IFR18650-11P 1100/10A 3.2 3.6 0.5 2 0.2 18 - 65 43 LFP 、
富利佳電子/edge electronics
朱俊/ AndyZhu
Tel: 86-755-61181811-608
Fax: 86-755-61181889
Mobile:86-13825228661
MSN: andyzhugf@126.com
Email:andy.zhu@edgeele.com
QQ: 173973178
Web: www.edgeelectronics.com
