[AVR单片机] 请教高手如何使用attiny2313的T1比较匹配功能
3442|4
 楼主| guxiang 发表于 2007-5-6 15:35 | 显示全部楼层 |阅读模式
定时器T1使用了捕获功能,同时还要使用T1A比较匹配功能,在PB3输出波形.捕获发生时清TICOUNT计数器,同时希望PB3输出低电平,当T1COUNT与OCR1A相等时比较匹配,PB3输出高电平.请问该如何操作比较匹配输出单元?
avrvi 发表于 2007-5-6 20:23 | 显示全部楼层
我写的PWM教程,希望对你有点帮助
教程是基于ICC的,mega16的程序。
http://www.avrvi.com/avr_examples/pwm.html
相关链接:http://www.avrvi.com
 楼主| guxiang 发表于 2007-5-6 22:10 | 显示全部楼层
回复avrvi
谢谢AVRVI先生的回帖.我的意图不是做PWM输出,而是而是对一个信号捕捉,然后再准确的延时一个固定时间.原程序如下,错在哪里?
//ICC-AVR application builder : 2007-5-2 12:56:18
// Target : T2313
// Crystal: 3.93216Mhz
#include <iot2313v.h>
#include <macros.h>
unsigned char flag=1,il,ih;
#pragma interrupt_handler timer1_capt_isr:4
void timer1_capt_isr(void)
  //TCCR1B = 0x00; //stop timer
 TCNT1H = 0x00; //set count value
 TCNT1L = 0x00;//analog comparator compare event
  TCCR1C=0X80;
  NOP();
  TCCR1C=0X00;
  TCCR1A=0xc0;
 if(flag)
   il=ICR1L;
   ih=ICR1H;
   flag=0;
#pragma interrupt_handler timer1_compa_isr:5
void timer1_compa_isr(void)
 TCCR1A = 0x80;
#pragma interrupt_handler timer1_ovf_isr:6
void timer1_ovf_isr(void)
void main(void)
 //stop errant interrupts until set up
 CLI(); //disable all interrupts
 PORTA = 0x00;
 DDRA  = 0x00;
 PORTD = 0x00;
 DDRD  = 0x00;
 PORTB = 0x00;
 DDRB  = 0x1c;
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9600 (0.0%)
 UCSRB = 0x00; //disable while setting baud rate
 UCSRC = 0x06;
 UBRRH = 0x00; //set baud rate upper
 UBRRL = 0x19; //set baud rate lower
 UCSRA = 0x00;
 UCSRB = 0x18; //enable
//Comparator initialize
// trigger on: Rising output edge
 ACSR = 0x06; //下降沿触发、捕获
//TIMER1 initialize - prescale:1
// WGM: 0) Normal, TOP=0xFFFF
// desired value: 550uSec
// actual value: 549.825uSec (0.0%)
 TCNT1L = 0x00; //set count value
 OCR1AH  = 0x08; //set compare value
 OCR1AL  = 0x72;
 TCCR1A = 0xc0;
 TCCR1B = 0x01; //start Timer
 MCUCR = 0x00;
 GIMSK = 0x00;
 TIMSK = 0xC8;
 SEI(); //re-enable interrupts
 //all peripherals are now initialized
 while(1)
while(!flag)
 UDR = ih;
 while(!(UCSRA&0x20));
  UCSRA |= 0x20;
  UDR = il;
  UCSRA |= 0x20;
  UDR = 0x0d ;
  UCSRA |= 0x20;
  UDR = 0x0a ;
  UCSRA |= 0x20;
  //UCSRB = 0x0C; //enable
  flag=1;
ayb_ice 发表于 2007-5-7 11:25 | 显示全部楼层
datasheet...
 楼主| guxiang 发表于 2007-5-8 07:54 | 显示全部楼层
谢谢2楼
不错,为我提供了另一种思路,谢谢2楼的大侠。
