[AVR单片机]
那位帮看看这段程序有什么问题吗 ?读取74LS165的程序
2240|2
fleshyao|  楼主 | 2012-6-27 20:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PC3Á¬½ÓSH/LD--STOR£¬PC2Á¬½ÓCLK--CLK,PC4Á¬½ÓQH--DATA£¬
#include <iom128v.h>
#include <macros.h>
#include "config.h"
#define uchar     unsigned char
#define uint      unsigned int
#define nop  NOP()
#define SET_LOAD           PORTC |= (1<<PC3)
#define CLR_LOAD           PORTC &= ~(1<<PC3)
#define SET_CLK      PORTC |= (1<<PC2)
#define CLR_CLK      PORTC &= ~(1<<PC2)
#define Ls165_data   PINC & (1 << PINC4)
#define CLR_EAST_EN    PORTB &= ~(1 << PB0)
#define SET_EAST_EN    PORTB |= (1 << PB0)
uchar read_ls165[2];
void Read_LS165(void)
         uchar j,i,key_code;
         PORTC = 0x0c;
   DDRC=0x0c;
         //DDRC |= (1<<SH_LD) | (1<<CLK); //PD0,PD1 OUTPUT ,PD2 INPUT
   while(1)
           CLR_LOAD;
     delay_ms(10);
           SET_LOAD ;
           CLR_EAST_EN;
     delay_ms(1);
                 for(j=0;j<2;j++)
                     for(i=0;i<8;i++)
                         read_ls165[j]<<=1;
       if(Ls165_data)
                       read_ls165[j] |=Ls165_data;
                         CLR_CLK;
                         delay_ms(1);
                         SET_CLK;
                 CLR_CLK;
      delay_ms(1);
                 SET_CLK;
           SET_EAST_EN;
NE5532| | 2012-6-29 19:55 | 只看该作者
请楼主自己加注释行,不加注释行的程序直接无视。
