[N32G45x] 基于N32G457QEL7开发Systick配置
24|1
小海师 发表于 2026-3-12 07:07 | 显示全部楼层 |阅读模式
一、在SYSTEM文件夹下增加system_cortex_m_systick.c/n32g45x_it.c和system_cortex_m_systick.h/n32g45x_it.h,SystemTypedef.h文件,并添加之项目工程中;
二、实现Systick的软件配置;
#include "system_cortex_m_systick.h"
#include "n32g45x.h"
volatile static u32 g_systick = 0;
    \brief      this function handles SysTick exception
    \param[in]  none
    \param[out] none
    \retval     none
void SysTick_Handler(void)
    g_systick++;
    \brief      configure systick  1ms
    \param[in]  none
    \param[out] none
    \retval     none
void System_SystickConfig(void)
    /* setup systick timer for 1000Hz interrupts */
    if(SysTick_Config(SystemCoreClock / 1000U)) {
        /* capture error */
        while(1) {
    /* configure the systick handler priority */
    NVIC_SetPriority(SysTick_IRQn, 0x00U);
    \brief      delay a time in milliseconds
    \param[in]  count: count in milliseconds
    \param[out] none
    \retval     none
void System_SystickDelay_ms(u32 n_ms)
    u32 cur_tick = g_systick;
    while((g_systick-cur_tick) <= n_ms){}
#ifndef __SYSTEM_CORTEX_M_SYSTICK_H_
#define __SYSTEM_CORTEX_M_SYSTICK_H_
#include "SystemTypedef.h"
    \param[in]  none
    \param[out] none
    \retval     none
void System_SystickConfig(void);
    \param[out] none
    \retval     none
void System_SystickDelay_ms(u32 n_ms);
#endif
SystemTypedef.h
#ifndef __SYSTEM_TYPEDEF_H
#define __SYSTEM_TYPEDEF_H
#ifndef NULL
#define NULL 0
#endif
#ifndef Myself_DATA_TYPE
typedef unsigned long long u64;
typedef unsigned int u32;
typedef unsigned short u16;
typedef unsigned char u8;
typedef long long s64;
typedef int s32;
typedef short s16;
typedef const unsigned char uc8;
typedef volatile unsigned int vu32;
#endif
#endif
n32g45x_it.c
* @file n32g45x_it.c
* @author Nations
* @version v1.0.1
* @CopyRight Copyright (c) 2019, Nations Technologies Inc. All rights reserved.
#include "n32g45x_it.h"
/** @addtogroup N32G45X_StdPeriph_Template
/*            Cortex-M4 Processor Exceptions Handlers                         */
* @brief  This function handles NMI exception.
void NMI_Handler(void)
* @brief  This function handles Hard Fault exception.
void HardFault_Handler(void)
    /* Go to infinite loop when Hard Fault exception occurs */
    while (1)
* @brief  This function handles Memory Manage exception.
void MemManage_Handler(void)
    /* Go to infinite loop when Memory Manage exception occurs */
    while (1)
* @brief  This function handles Bus Fault exception.
void BusFault_Handler(void)
    /* Go to infinite loop when Bus Fault exception occurs */
    while (1)
* @brief  This function handles Usage Fault exception.
void UsageFault_Handler(void)
    /* Go to infinite loop when Usage Fault exception occurs */
    while (1)
* @brief  This function handles SVCall exception.
void SVC_Handler(void)
* @brief  This function handles Debug Monitor exception.
void DebugMon_Handler(void)
/*                 N32G45X Peripherals Interrupt Handlers                     */
/*  Add here the Interrupt Handler for the used peripheral(s) (PPP), for the  */
/*  available peripheral interrupt handler's name please refer to the startup */
/*  file (startup_n32g45x.s).                                                 */
* @brief  This function handles PPP interrupt request.
/*void PPP_IRQHandler(void)
n32g45x_it.h
* @file n32g45x_it.h
* @author Nations
* @version v1.0.0
* @copyright Copyright (c) 2019, Nations Technologies Inc. All rights reserved.
#ifndef __N32G45X_IT_H__
#define __N32G45X_IT_H__
#ifdef __cplusplus
extern "C" {
#endif
void NMI_Handler(void);
void HardFault_Handler(void);
void MemManage_Handler(void);
void BusFault_Handler(void);
void UsageFault_Handler(void);
void SVC_Handler(void);
void DebugMon_Handler(void);
void PendSV_Handler(void);
#ifdef __cplusplus
#endif
#endif /* __N32G45X_IT_H__ */
main.c
int main(void)
    System_SystickConfig();
    while(1)
    return 0;
三,进行软件代码的编译,下载验证;
四,仿真运行软件后,可以查看到systick每间隔1ms自增1;
将软件断点设置在SysTick_Handler也能够正常触发;
软件运行均正常,说明配置成功;
版权声明:本文为CSDN博主「小吴同学啊」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/weixin_43647919/article/details/157978520
OKAKAKO 发表于 2026-7-29 23:46 | 显示全部楼层
基于N32G457QEL7开发Systick配置很详细的教程
