AT91SAM7X128编程笔记之PIO
2302|0
 楼主| feng_710 发表于 2012-6-29 16:32 | 显示全部楼层 |阅读模式
1.时能PIO时钟  AT91C_BASE_PMC->PMC_PCER  = 1 << AT91C_ID_PIOA;
  AT91C_BASE_PMC->PMC_PCER  = 1 << AT91C_ID_PIOB;
2.设置为I/O功能
   AT91C_BASE_PIOB->PIO_PER   = AT91C_PIO_PB18;
3.设置为输出或输入模式
  AT91C_BASE_PIOB->PIO_OER   = AT91C_PIO_PB18;//输出
  AT91C_BASE_PIOB->PIO_ODR  = AT91C_PIO_PA26;//输入
4.输出或读取
AT91C_BASE_PIOB->PIO_CODR = AT91C_PIO_PB18;//输出0
AT91C_BASE_PIOB->PIO_SODR = AT91C_PIO_PB18;//输出1
unsigned int n;
n =AT91C_BASE_PIOA->PIO_PDSR;
