[AVR单片机] 求助:GCC内嵌汇编警告
2335|2
 楼主| ATmega16 发表于 2007-7-11 21:53 | 显示全部楼层 |阅读模式
16位有符号数除法
div16_t divs16_s16(int16_t val0,int16_t val1)
div16_t result;
asm(
        "movw    r24,%A1"            " "
        "movw    r22,%A2"            " "
        "mov    r2,r25"                " "
        "sbrc    r2,7"                " "
        "rcall    1f"                    " "
        "mov    r3,r23"                " "
        "sbrc    r3,7"                " "
        "rcall    2f"                    " "
        "call    __udivmodhi4"        " "
        "sbrc    r2,7"                " "
        "rcall    1f"                    " "
        "eor    r3,r2"                " "
        "sbrc    r3,7"                " "
        "rcall    2f"                    " "
        "rjmp    3f"                    " "
"1:"    "com    r25"                " "
        "neg    r24"                " "
        "sbci    r25,0xff"            " "
        "ret"                        " "
"2:"    "com    r23"                " "
        "neg    r22"                " "
        "sbci    r23,0xff"            " "
        "ret"                        " "
"3:"    "movw    %A0,r22"            " "
        "movw    %C0,r24"            " "
:"r="(result)
:"r"(val0),"r"(val1)
:"r2","r3","r22","r23","r24","r25"
    return result;
总是产生警告,求高手指点。
John_Lee 发表于 2007-7-12 10:37 | 显示全部楼层
警告已经说得很明白了
 楼主| ATmega16 发表于 2007-7-12 16:18 | 显示全部楼层
低级失误
不是"r=",是"=r"
