12864显示温度字模数组KEIL编译提示错误
2594|4
 楼主| chenyu988 发表于 2012-7-4 21:57 | 显示全部楼层 |阅读模式
用不带字库的12864显示温度,把0-9的字模放在数组中uchar code number[][10]
当编译提示错误error C242: 'array[]': too many initializers
该怎么解决呢?
shell.albert 发表于 2012-7-4 22:02 | 显示全部楼层
1# chenyu988
Keil的编译器支持二维数组,第一维不写具体的值吗?
如何写成uchar code number[10][10]呢?
下标是0~9
这显示是语法错误。
试试如下的代码:
uchar code number[][10]=
{0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09
多变换几次写法,重新定义。多试几次就能找到问题所在。你对C数组的定义初始化还不是很明白。
 楼主| chenyu988 发表于 2012-7-4 22:05 | 显示全部楼层
2# shell.albert
写成uchar code number[10][10]编译还是不行
 楼主| chenyu988 发表于 2012-7-4 22:07 | 显示全部楼层
{{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},/*0*/
{0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},/*1*/
{0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},/*2*/
{0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00},/*3*/
{0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00},/*4*/
{0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00},/*5*/
{0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00},/*6*/
{0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00},/*7*/
{0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},/*8*/
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00},/*9*/};
提示出错
 楼主| chenyu988 发表于 2012-7-4 22:14 | 显示全部楼层
额发现了 每个组数里有16个元素改成uchar code number[][16]  好了
