CRC16 算法出错
4020|7
 楼主| ljm041128 发表于 2012-7-6 15:35 | 显示全部楼层 |阅读模式
    描    述: CRC16校验查表子程序,速度快,占用空间大
    入口参数: 指向数组指针,校验字节个数
    出口参数: 16位CRC校验码
unsigned int CRC16(unsigned char *pcrc, unsigned char count)
    unsigned int crc16 = 0;
    unsigned char crcregister;
    for( ; count > 0; count--){
        crcregister = (unsigned int)crc16 >> 8;
        crc16 <<= 8;
        crc16 ^= CRC16Table[crcregister ^ *pcrc];
        pcrc++;
    return (crc16);
以上是代码。
表格:
const rom unsigned int CRC16Table[256]={               /* CRC16 余式表 */
    0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50a5, 0x60c6, 0x70e7,
    0x8108, 0x9129, 0xa14a, 0xb16b, 0xc18c, 0xd1ad, 0xe1ce, 0xf1ef,
    0x1231, 0x0210, 0x3273, 0x2252, 0x52b5, 0x4294, 0x72f7, 0x62d6,
    0x9339, 0x8318, 0xb37b, 0xa35a, 0xd3bd, 0xc39c, 0xf3ff, 0xe3de,
    0x2462, 0x3443, 0x0420, 0x1401, 0x64e6, 0x74c7, 0x44a4, 0x5485,
    0xa56a, 0xb54b, 0x8528, 0x9509, 0xe5ee, 0xf5cf, 0xc5ac, 0xd58d,
    0x3653, 0x2672, 0x1611, 0x0630, 0x76d7, 0x66f6, 0x5695, 0x46b4,
    0xb75b, 0xa77a, 0x9719, 0x8738, 0xf7df, 0xe7fe, 0xd79d, 0xc7bc,
    0x48c4, 0x58e5, 0x6886, 0x78a7, 0x0840, 0x1861, 0x2802, 0x3823,
    0xc9cc, 0xd9ed, 0xe98e, 0xf9af, 0x8948, 0x9969, 0xa90a, 0xb92b,
    0x5af5, 0x4ad4, 0x7ab7, 0x6a96, 0x1a71, 0x0a50, 0x3a33, 0x2a12,
    0xdbfd, 0xcbdc, 0xfbbf, 0xeb9e, 0x9b79, 0x8b58, 0xbb3b, 0xab1a,
    0x6ca6, 0x7c87, 0x4ce4, 0x5cc5, 0x2c22, 0x3c03, 0x0c60, 0x1c41,
    0xedae, 0xfd8f, 0xcdec, 0xddcd, 0xad2a, 0xbd0b, 0x8d68, 0x9d49,
    0x7e97, 0x6eb6, 0x5ed5, 0x4ef4, 0x3e13, 0x2e32, 0x1e51, 0x0e70,
    0xff9f, 0xefbe, 0xdfdd, 0xcffc, 0xbf1b, 0xaf3a, 0x9f59, 0x8f78,
    0x9188, 0x81a9, 0xb1ca, 0xa1eb, 0xd10c, 0xc12d, 0xf14e, 0xe16f,
    0x1080, 0x00a1, 0x30c2, 0x20e3, 0x5004, 0x4025, 0x7046, 0x6067,
    0x83b9, 0x9398, 0xa3fb, 0xb3da, 0xc33d, 0xd31c, 0xe37f, 0xf35e,
    0x02b1, 0x1290, 0x22f3, 0x32d2, 0x4235, 0x5214, 0x6277, 0x7256,
    0xb5ea, 0xa5cb, 0x95a8, 0x8589, 0xf56e, 0xe54f, 0xd52c, 0xc50d,
    0x34e2, 0x24c3, 0x14a0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
    0xa7db, 0xb7fa, 0x8799, 0x97b8, 0xe75f, 0xf77e, 0xc71d, 0xd73c,
    0x26d3, 0x36f2, 0x0691, 0x16b0, 0x6657, 0x7676, 0x4615, 0x5634,
    0xd94c, 0xc96d, 0xf90e, 0xe92f, 0x99c8, 0x89e9, 0xb98a, 0xa9ab,
    0x5844, 0x4865, 0x7806, 0x6827, 0x18c0, 0x08e1, 0x3882, 0x28a3,
    0xcb7d, 0xdb5c, 0xeb3f, 0xfb1e, 0x8bf9, 0x9bd8, 0xabbb, 0xbb9a,
    0x4a75, 0x5a54, 0x6a37, 0x7a16, 0x0af1, 0x1ad0, 0x2ab3, 0x3a92,
    0xfd2e, 0xed0f, 0xdd6c, 0xcd4d, 0xbdaa, 0xad8b, 0x9de8, 0x8dc9,
    0x7c26, 0x6c07, 0x5c64, 0x4c45, 0x3ca2, 0x2c83, 0x1ce0, 0x0cc1,
    0xef1f, 0xff3e, 0xcf5d, 0xdf7c, 0xaf9b, 0xbfba, 0x8fd9, 0x9ff8,
    0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0
每次CRC0数据结果都不一样
baoshi_libo 发表于 2012-7-6 20:27 | 显示全部楼层
unsigned int crc16(unsigned char *message, unsigned int len)
        unsigned int crc=0;
        while(len--)
                crc=(crc<<8)^CRC16Table[((crc>>8)^*message++)&0xff];
        return crc;
XIEYUANBIN 发表于 2012-7-8 15:05 | 显示全部楼层
CRC是一种串行数据校验,你要注意数据是以低位先入还是高位先入,16位的还要注意是低8位在前还是高8位在前。
 楼主| ljm041128 发表于 2012-7-9 10:30 | 显示全部楼层
谢谢2楼的兄弟,不过用你的这段代码结果一样,前面得需校验的数据数据区完全相同,但每次结果就是不一样,是不是和PIC单片机查表方式特殊有关,高手请指点!
兰天白云 发表于 2012-7-9 14:08 | 显示全部楼层
CRC检验本人也采用查表方式,未发现楼主说的问题,还是自己查一查代码吧
 楼主| ljm041128 发表于 2012-7-9 16:31 | 显示全部楼层
哈哈,是我的代码有误!
hotpower 发表于 2015-9-27 13:16 来自手机 | 显示全部楼层
http://www.21ic.com/tools/HotWC3_V1.11.html
hotpower 发表于 2015-9-27 13:17 来自手机 | 显示全部楼层
它可以自动生成表格和源程序
