[STM32L0] CRC 计算结果错误
11|0
zhang..yb 发表于 2026-8-26 11:14 | 显示全部楼层 |阅读模式
static const uint32_t aDataBuffer[10] =
  0x0407, 0xaa35, 0x07e7, 0x05, 0x16, 0x0,
  0x0, 0x0
CrcHandle.Instance = CRC;
  /* The default polynomial is used */
  CrcHandle.Init.DefaultPolynomialUse    = DEFAULT_POLYNOMIAL_ENABLE;
  /* The default init value is used */
  CrcHandle.Init.DefaultInitValueUse     = DEFAULT_INIT_VALUE_ENABLE;
  /* The input data are not inverted */
  CrcHandle.Init.InputDataInversionMode  = CRC_INPUTDATA_INVERSION_NONE;
  /* The output data are not inverted */
  CrcHandle.Init.OutputDataInversionMode = CRC_OUTPUTDATA_INVERSION_DISABLE;
  /* The input data are 32-bit long words */
  CrcHandle.InputDataFormat              = CRC_INPUTDATA_FORMAT_WORDS;
  if (HAL_CRC_Init(&CrcHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
  uwCRCValue = HAL_CRC_Calculate(&CrcHandle, (uint32_t *)aDataBuffer, 5);
结果为 0
