[STM32C5] 【STM32C5 开发板评测】三、点灯,点个呼吸灯
29|0
地瓜patch 发表于 2026-9-2 21:08 | 显示全部楼层 |阅读模式
接上贴,继续未完成的点灯。
CubeMX2生成的工程还是有个熟悉过程的。
MX2生成的工程树如下图。
其生成的main.c文件极为简单, main() 非常干净,调用mx_system_init()函数,然后就是while (1) {}。
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private functions prototype -----------------------------------------------*/
  * brief:  The application entry point.
  * retval: none but we specify int to comply with C99 standard
int main(void)
  /** System Init: this code placed in targets folder initializes your system.
    * It calls the initialization (and sets the initial configuration) of the peripherals.
    * You can use STM32CubeMX to generate and call this code or not in this project.
    * It also contains the HAL initialization and the initial clock configuration.
  if (mx_system_init() != SYSTEM_OK)
    return (-1);
  else
      * You can start your application code here
    while (1) {}
} /* end main */
mx_system_init()函数在mx_system.c中定义。在mx_system_init()函数有如下说明,mx_tim1_init()在mx_tim1.c中声明。
/** TIM1: mx_tim1_init() has been generated,
    * but it is expected that application will call it when best needed
    * according to application needs.
    * See Cube code generator options: Generate and call Initialization function
目标是实现LED1的呼吸灯效果,在这个基础上改。需要做 3 件事:手动调用 mx_tim1_init();配 PA5 = AF2(GPIO 复用);启动 TIM1实现呼吸循环。
首先,初始化TIM1,
    LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOA);
    hal_tim_handle_t *htim1 = mx_tim1_init();
    if (htim1 == NULL)
      while (1);   // ?????,??
mx_tim1_init()函数中用 HAL2 的方式初始化 hTIM1 句柄,绑定 HAL_TIM1 这个外设标识。返回 hal_tim_handle_t*。并开启 TIM1 时钟,配定时器基本参数包括分频参数,计数方式等。配 CH3 为 PWM mode 1,初始 pulse = 0x200。
其次,将PA5映射到TIM1_CH3。
LL_GPIO_SetPinMode(GPIOA, LL_GPIO_PIN_5, LL_GPIO_MODE_ALTERNATE);
    LL_GPIO_SetAFPin_0_7(GPIOA, LL_GPIO_PIN_5, 2);  // AF1
    LL_GPIO_SetPinOutputType(GPIOA, LL_GPIO_PIN_5, LL_GPIO_OUTPUT_PUSHPULL);
    LL_GPIO_SetPinSpeed(GPIOA, LL_GPIO_PIN_5, LL_GPIO_SPEED_FREQ_HIGH);
    LL_GPIO_SetPinPull(GPIOA, LL_GPIO_PIN_5, LL_GPIO_PULL_NO);
再次,使能TIM1_CH3输出
   LL_TIM_CC_EnableChannel(TIM1, LL_TIM_CHANNEL_CH3);   // CC3E
    LL_TIM_EnableAllOutputs(TIM1);                       // MOE,??
    LL_TIM_EnableCounter(TIM1);                          // CEN
最后,就是配置初始化参数,计数初值
uint32_t arr = LL_TIM_GetAutoReload(TIM1);  // 0xFFFF
    int32_t pwm = 0x200;
    int32_t step = 300;
    /* USER CODE END 2 */
    while (1)
      /* USER CODE BEGIN WHILE */
      LL_TIM_OC_SetCompareCH3(TIM1, (uint32_t)pwm);
      pwm += step;
      if (pwm >= (int32_t)arr)
        pwm = (int32_t)arr;
        step = -100;
      else if (pwm <= 0)
        pwm = 0;
        step = 100;
      HAL_Delay(1);
      /* USER CODE END WHILE */
经过以上定时器的参数配置,就可以实现呼吸灯效果。想要改变呼吸效果的话,改变while()中的 step 赋值,其绝对值越大,呼吸效果越快。反之更慢。
呼吸效果视频如下:
Stm32CubeMX2生成的MDK工程如下:
stm32c5_Led_open-cmsis.zip (17.09 MB, 下载次数: 0)
个人签名:出一块TI-PLABS-AMP-EVM
2990
