[STM32H7] I2S DMA 音频卡顿问题
52|0
小库里 发表于 2026-9-22 20:42 | 显示全部楼层 |阅读模式
我目前正在做一个扬声器项目,音频数据通过 SPI 从 microSD 卡读取,再通过 I2S 配合 DMA 发送出去。我注意到主要问题在于 SD 卡的延迟,有人建议我使用三重指针环形缓冲区。但没找到例程。我自己写了一个程序也没有成功。代码如下,有没有人推荐一些学习这方面内容的好资源?
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_I2S1_Init();
  MX_SPI2_Init();
  MX_USART2_UART_Init();
  if (MX_FATFS_Init() != APP_OK) {
    Error_Handler();
  /* USER CODE BEGIN 2 */
  fres = f_mount(&fat, "", 1);
  if(fres != FR_OK){
      char buf[32];
      snprintf(buf, sizeof(buf), "MOUNT ERR: %d\r\n", fres);
      while(1){
          HAL_UART_Transmit(&huart2, (uint8_t*)buf, strlen(buf), 1000);
          HAL_Delay(1000);
  else
          printf("\n\r-----Drive mounted!-------\n\r");
  fres = f_open(&file,"yeat.wav",FA_READ);
  if(fres != FR_OK)
          printf("\n\rDid not open file!\n\r");
  else
          printf("\n\rOpened yeat.wav!\n\r");
  int16_t bitsPerSample;
  int16_t numChannels;
  int16_t audioFormat;
  f_lseek(&file,24);
    f_read(&file,&sample_rate,4,bytes_read);
  f_lseek(&file,40);
  f_read(&file,&recording_size,4,bytes_read);
  f_lseek(&file,34);
  f_read(&file,&bitsPerSample,2,bytes_read);
  f_lseek(&file,22);
  f_read(&file,&numChannels,2,bytes_read);
  f_lseek(&file,20);
  f_read(&file,&audioFormat,2,bytes_read);
  printf("\n\rNum of Channels: %d\n\r",numChannels);
  printf("\n\rAudio format: %d\n\r",audioFormat);
  printf("\n\rRecording size: %ld\n\r",recording_size);
  printf("\n\rBitsPerSample: %d\n\r",bitsPerSample);
  printf("\n\rSample_rate: %ld\n\r",sample_rate);
  f_lseek(&file,44);
  f_read(&file,read,BUFFER_SIZE,bytes_read);
  read_full = 1;
  HAL_I2S_Transmit_DMA(&hi2s1,read,16000);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
          if(write_full == 0){
                  f_read(&file,write,BUFFER_SIZE,bytes_read);
                  write_full = 1;
          if(spare_full == 0 && write_full == 1){
                  memcpy(spare,write,sizeof(write));
                  write_full = 0;
                  spare_full = 1;
          if(spare_full == 1 && read_full == 0){
                  memcpy(read,spare,sizeof(spare));
                  read_full = 1;
                  spare_full = 0;
  /* USER CODE END 3 */
