protel 2004布线规则问题。。。
5645|4
dove强|  楼主 | 2012-7-9 12:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我都已经把规则调到了0mm,怎么还不能消除这类错误呢?大家帮帮忙呗。。。
Errors and Warnings - 67 Errors 0 Warnings 1 Hint
Error : Pad U3-3 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad U3-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad U3-5 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad U3-4 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad U3-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad *J2-3 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad *J2-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad *J2-5 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad *J2-4 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad *J2-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad C3-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad C3-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad C6-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad C6-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad C8-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad C8-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad D1-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad D1-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad D2-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad D2-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS0-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS0-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS1-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS1-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS2-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS2-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS3-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS3-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS4-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS4-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS5-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad DS5-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad L1-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad L1-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad R1-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad R1-2 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
Error : Pad R2-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=0mm) (All),(All) Detected.
dove强|  楼主 | 2012-7-9 13:51 | 只看该作者
而且还不能画直线了,只要画线,整个PCB板就闪烁!这是个什么情况。。。
tee.| | 2012-7-9 15:02 | 只看该作者
没遇到过额,遇到过的人进来看看吧
zhuls| | 2012-7-10 19:59 | 只看该作者
没见过。。
zshnshn| | 2015-10-15 15:52 | 只看该作者
楼主后来怎么解决了
