launch pad有谁调试过串口的了?
2099|0
 楼主| aliming 发表于 2012-7-11 11:24 | 显示全部楼层 |阅读模式
用TI官网上的例子,串口调试助手,老看不到收到的数据,谁试过的?
代码://******************************************************************************
//   MSP430G2xx3 Demo - USCI_A0, 9600 UART Echo ISR, DCO SMCLK
//   Description: Echo a received character, RX ISR used. Normal mode is LPM0.
//   USCI_A0 RX interrupt triggers TX Echo.
//   Baud rate divider with 1MHz = 1MHz/9600 = ~104.2
//   ACLK = n/a, MCLK = SMCLK = CALxxx_1MHZ = 1MHz
//                MSP430G2xx3
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |     P1.2/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P1.1/UCA0RXD|<------------
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include  "msp430g2553.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  BCSCTL1 = CALBC1_1MHZ;                    // Set DCO
  DCOCTL = CALDCO_1MHZ;
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P2DIR = 0xff;
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 104;                            // 1MHz 9600
  UCA0BR1 = 0;                              // 1MHz 9600
  UCA0MCTL = UCBRS0;                        // Modulation UCBRSx = 1
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
//  Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
  UCA0TXBUF = UCA0RXBUF;// TX -> RXed character
