MSP430g2553 timerA中断问题
2681|1
 楼主| tianjiantian 发表于 2012-7-11 17:50 | 显示全部楼层 |阅读模式
代码:#include <msp430g2553.h>
#include "LCDdriver.h"
#include "normal.h"
unsigned  int TA_OV=0;
float period=0;
unsigned int per=0;
void CLK_init(void)
BCSCTL1 |= CALBC1_1MHZ;
DCOCTL |= CALDCO_1MHZ;//上面两句将内部DCO校准至1MHz
//while(IFG1&OFIFG)
//IFG1 &= ~OFIFG;
//delay_ms(100);
BCSCTL2 |= SELM_0;//MCLK采用1M的内部DCO
BCSCTL2 |= DIVS_2;//SMCLK采用250K的时钟
}        //时钟初始化
void main(void) {
WDTCTL =WDTPW+WDTHOLD;
CLK_init();
P1DIR &=~BIT2;        //P1.2  TA0.1
P1SEL |=BIT2;
lcdinit();
TACTL =TASSEL_1+MC_2+TAIE+TACLR;
TACCTL1 =CAP +CM_1+CCIS_1+SCS+CCIE;   //捕获模块1o
_EINT();
LPM3;
#pragma vector=TIMER0_A1_VECTOR
__interrupt void TIMER_A0 (void){
switch(TAIV){
case 2:  period = (TA_OV*65536+TA0R-per);
         per=TA0R;
         TA_OV=0;
         display_hanz(1,1,"频率为:");
         LCD_DispDec(2,1,period,6,3);
         break;
case 4:break;
case 10: TA_OV++; break;          //yi chu
 楼主| tianjiantian 发表于 2012-7-11 17:53 | 显示全部楼层
为什么进不了中断、、、、、、
