[STM32L1] STM32L152 SPI 通信问题
9129|17
 楼主| kanta 发表于 2012-7-14 23:35 | 显示全部楼层 |阅读模式
我现在使用的是STM32L152,用了两个ST的开发板,用SPI2进行通信,通信不成功,软件配置如下:
void SPI_INIT()
  SPI_InitTypeDef SPI_InitStructure;
  //EXTI_InitTypeDef EXTI_InitStructure;
  //NVIC_InitTypeDef NVIC_InitStructure;
  SPI_Cmd(SPI2,DISABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); //使能GPIOB 时钟
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  /*!< Configure SPI_FLASH_SPI pins: SCK */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_15;// 初始化指定管脚
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;// //
GPIO_Mode_AF   = 0x02, /*!< GPIO Alternate function Mode */
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;// 推挽方式输出 还是 集电极开路方式输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;//
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /*!< Configure SPI_FLASH_SPI pins: MISO */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_14;// 初始化指定管脚
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;// 管脚工作模式:输出
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;// 输入时上(下)拉状态:上拉
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;// 管脚输出的速度
  SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;//2线全双工
  SPI_InitStructure.SPI_Mode=SPI_Mode_Master;//SPI主设备
  SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b;//SPI传输数据8位
  SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low;//时钟极性为低跳变到高采集数据
  SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge;//时钟相位(第一个跳变沿采集数据)
  SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;//片选方式
  SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_16;//波特率预分频,16分频
  SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB;;//指定数据传输从MSB位还是LSB位开始
  SPI_InitStructure.SPI_CRCPolynomial=7;//设置crc多项式
  SPI_Init(SPI2,&SPI_InitStructure);
  //SPI_Cmd(SPI2,ENABLE);
/*Enable SPI1.NSS as a GPIO*/
  SPI_SSOutputCmd(SPI1, ENABLE);
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode=GPIO_OType_PP;
主函数如下:
int main(void)
  unsigned int i,j;
  SystemInit();
  SPI_INIT();
  /* Check if the StandBy flag is set */
  if (PWR_GetFlagStatus(PWR_FLAG_SB) != RESET)
    /* System resumed from STANDBY mode */
    /* Clear StandBy flag */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);//清除标志位
    PWR_ClearFlag(PWR_FLAG_SB);
    /* set StandbyWakeup indicator*/
    //StanbyWakeUp = TRUE;
  else
    /* Reset StandbyWakeup indicator*/
   // StanbyWakeUp = FALSE;
  enableInterrupts();
  while(1)
    GPIO_ResetBits(GPIOB, GPIO_Pin_12);
    while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_BSY )!= RESET)//线路忙则等待
    SPI_I2S_SendData(SPI2, 0x01);
    GPIO_SetBits(GPIOB, GPIO_Pin_12);
    GPIO_SetBits(GPIOB, GPIO_Pin_6);// GPIO_Pin_6输出为1
    GPIO_SetBits(GPIOB, GPIO_Pin_7);// GPIO_Pin_7输出为1
    Delay(200);
    GPIO_ResetBits(GPIOB, GPIO_Pin_6);// GPIO_Pin_6输出为0
    GPIO_ResetBits(GPIOB, GPIO_Pin_7);// GPIO_Pin_7输出为0
    Delay(200);
    /*for( i=BufferSize; i>0; i-- )
       TI_CC_SPIStrobe(SIDLE);
       TI_CC_SPIWriteBurstReg(TXFIFO,SPI2_Buffer_Tx,BufferSize);
       TI_CC_SPIStrobe(STX);
     Delay(200);*/
SPI2从机的配置如下:
void SPI_INIT()
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); //使能GPIOA 时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_15;// 初始化指定管脚
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;// 管脚工作模式:输出//
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;// 输入时上(下)拉状态:
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;// 管脚输出的速度:
  SPI_InitStructure.SPI_Mode=SPI_Mode_Slave;//SPI从设备
  //SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_16;//波特率预分频,16分频
主函数如下:
#define enableInterrupts()   __set_PRIMASK(0);
int main(void)
  unsigned int i,j;
  SystemInit();
  SPI_INIT();
  else
  enableInterrupts();
  while(1)
     while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_RXNE )!= RESET)//线路忙则等待
    i=SPI_I2S_ReceiveData(SPI2);
    if(i!=0)
      Delay(200);
      //while(1);
    else if(i==0)
      GPIO_ResetBits(GPIOB, GPIO_Pin_6);// GPIO_Pin_6输出为1
      //Delay(200);
从机读出的结果总是0;
没有示波器,没法看波形,麻烦各位帮我提提意见,看我的配置是否正确,先谢了。
 楼主| kanta 发表于 2012-7-15 08:52 | 显示全部楼层
 楼主| kanta 发表于 2012-7-15 10:06 | 显示全部楼层
看来周末没人啊
a868247 发表于 2012-7-16 14:55 | 显示全部楼层
楼主,搞的蛮快的
香水城 发表于 2012-7-16 15:27 | 显示全部楼层
STM32L的GPIO架构和STM32F1的略有不同
LZ请参考下例程代码
配置SPI需要额外调用
GPIO_PinAFConfig(GPIOX, GPIO_PinSourcex, GPIO_AF_SPIx);
LZ请参考下例程代码
配置SPI需要额外调用
zh5202 发表于 2012-7-16 16:50 | 显示全部楼层
最好还是找个示波器,打出波形一看就知道是哪里的问题了。
 楼主| kanta 发表于 2012-7-17 12:00 | 显示全部楼层
感谢各位的回复,昨天我用了GPIO_PinAFConfig(GPIOX, GPIO_PinSourcex, GPIO_AF_SPIx)后,总是出现硬件错误,掉到硬件中断里面出不来,还没找到原因
yinyangdianzi 发表于 2012-7-17 13:26 | 显示全部楼层
L系列勘误.pdf
237.16 KB, 下载次数: 90
F1升级L1.pdf
312 KB, 下载次数: 55
IJK 发表于 2012-7-17 14:51 | 显示全部楼层
没有示波器,调试确实很麻烦。但还是有办法的,其实用MCU的GPIO,也可以检测SPI有没有数据发送出来。
建议LZ先检查,SPI有没有数据发出?
figo20042005 发表于 2012-7-17 15:12 | 显示全部楼层
同意LS,可以用给数据发出程序里加一些现象用GPIO显示,看看是不是SPI有数据发出
 楼主| kanta 发表于 2012-7-17 22:28 | 显示全部楼层
OK,我试试看
 楼主| kanta 发表于 2012-7-17 23:19 | 显示全部楼层
我用了GPIO_PinAFConfig(GPIOB, GPIO_Pin_13, GPIO_AF_SPI2)后,程序一直在
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1);
}跳不出这个中断,我在网上了个网站好像是介绍这个问题的,非英文的没看明白
 楼主| kanta 发表于 2012-7-18 00:14 | 显示全部楼层
跳不出这个中断的问题找到了,我以前定义是
GPIO_PinAFConfig(GPIOB, GPIO_Pin_12, GPIO_AF_SPI2);
改成这样定义
GPIO_PinAFConfig(GPIOX, GPIO_PinSourcex, GPIO_AF_SPIx);就可以,具体原因未知,没时间仔细研究
figo20042005 发表于 2012-7-18 08:54 | 显示全部楼层
看来STM的配置定义很关键,很容易犯错,还需理解DATASHEET
zuowei43 发表于 2016-3-23 09:36 | 显示全部楼层
改成这 ...
楼主找到原因了吗?
zuowei43 发表于 2016-3-23 09:39 | 显示全部楼层
LZ请参考下例程代码
改成这样定义
直接这样调用?
Donil 发表于 2017-6-2 17:15 | 显示全部楼层
GPIO_Pin_12 并不是 GPIO_PinSourcex 而已
